Ana içeriğe geç
iRobot Roomba 870 Battery Replacement
  1. iRobot Roomba 870 Battery Replacement, Battery: adım 1, 2 resimden 1. iRobot Roomba 870 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • To access the iRobot Roomba 870 battery pack, first flip the Roomba upside down.
    • Then find the battery pack cover that is located in the space between the caster wheel, side brush, and vacuum.
    • Use a Phillips #0 screwdriver to remove the two 3.5mm screws on the battery pack cover.
  2. iRobot Roomba 870 Battery Replacement: adım 2, 3 resimden 1. iRobot Roomba 870 Battery Replacement: adım 2, 3 resimden 2. iRobot Roomba 870 Battery Replacement: adım 2, 3 resimden 3.
    • Remove the loose battery cover to access the battery compartment.
    • Use the yellow tabs, located on the short ends of the battery pack, to gently pull the battery up and out of its slot.
Sonuç
Follow the steps in reverse order for reassembly.
2 farklı kişi bu kılavuzu tamamladı.
Vitek Harvey
149 İtibar
1 Kılavuz yazıldı
Cal Poly, Team S14-G3, Banghart Spring 2017 Cal Poly, Team S14-G3, Banghart Spring 2017 üyesi
CPSU-BANGHART-S17S14G3
4 Üyeler
10 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 40
Her zaman: 2,991
