Ana içeriğe geç
iRobot Roomba 870 Main Wheel Replacement
Neye ihtiyacın var
  1. iRobot Roomba 870 Main Wheel Replacement, Main Wheel: adım 1, 2 resimden 1. iRobot Roomba 870 Main Wheel Replacement, Main Wheel: adım 1, 2 resimden 2.
    • While the Roomba is upside down, remove the 4.0mm screw surrounding the side brush using a Phillips #2 screwdriver.
    • Remove the brush.
  2. iRobot Roomba 870 Main Wheel Replacement: adım 2, 3 resimden 1. iRobot Roomba 870 Main Wheel Replacement: adım 2, 3 resimden 2. iRobot Roomba 870 Main Wheel Replacement: adım 2, 3 resimden 3.
    • Unscrew the four 3.5mm screws on the back cover using a Phillips #2 screwdriver.
    • Remove the back cover.
  3. iRobot Roomba 870 Main Wheel Replacement: adım 3, 3 resimden 1. iRobot Roomba 870 Main Wheel Replacement: adım 3, 3 resimden 2. iRobot Roomba 870 Main Wheel Replacement: adım 3, 3 resimden 3.
    • Unscrew the six 3.5mm screws using a Phillips #00 screwdriver. Each wheel has three screws.
    • Once all the screws are out, take out the wheels.
    I have taken the wheels out and cleaned all Oliver all around but the one wheel still does not turn brand new Wheels I put on it
    KERRY KELLY - Yanıt
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Andrew Cabri
330 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S14-G3, Banghart Spring 2017 Cal Poly, Team S14-G3, Banghart Spring 2017 üyesi
CPSU-BANGHART-S17S14G3
4 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
In step 3, the screw positions are just a bit off. They are not under the corners of the battery but under into the wheel housing.
aarond12 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 55
Her zaman: 4,585
