Ana içeriğe geç
iRobot Roomba 870 Side Brush Motor Replacement
  1. iRobot Roomba 870 Side Brush Motor Replacement, Side Brush Motor: adım 1, 3 resimden 1. iRobot Roomba 870 Side Brush Motor Replacement, Side Brush Motor: adım 1, 3 resimden 2. iRobot Roomba 870 Side Brush Motor Replacement, Side Brush Motor: adım 1, 3 resimden 3.
    • Turn the Roomba over so that the back side is facing up.
    • Using the Phillips #00 screwdriver, remove the 4.0mm screw in the center of the yellow side brush and lift the part out.
  2. iRobot Roomba 870 Side Brush Motor Replacement: adım 2, 2 resimden 1. iRobot Roomba 870 Side Brush Motor Replacement: adım 2, 2 resimden 2.
    • Use the Phillips #00 screwdriver to remove the four 3.5mm screws that hold down the battery panel and rear panel.
  3. iRobot Roomba 870 Side Brush Motor Replacement: adım 3, 2 resimden 1. iRobot Roomba 870 Side Brush Motor Replacement: adım 3, 2 resimden 2.
    • First remove the battery panel, which is the small rectangular.
    • After removing the battery panel, remove the rear panel.
  4. iRobot Roomba 870 Side Brush Motor Replacement: adım 4, 3 resimden 1. iRobot Roomba 870 Side Brush Motor Replacement: adım 4, 3 resimden 2. iRobot Roomba 870 Side Brush Motor Replacement: adım 4, 3 resimden 3.
    • Remove the three small 3.5mm screws fastened to the motor housing.
    • After removing the screws, remove the motor housing from the rest of the Roomba.
  5. iRobot Roomba 870 Side Brush Motor Replacement: adım 5, 3 resimden 1. iRobot Roomba 870 Side Brush Motor Replacement: adım 5, 3 resimden 2. iRobot Roomba 870 Side Brush Motor Replacement: adım 5, 3 resimden 3.
    • Remove the 2.5mm screw in the center of the motor housing using a Tri-Wing Y1 screwdriver.
    • After removing the screw, remove the top shell casing of the motor housing. Underneath, you will see a white gear with two screws next to it.
  6. iRobot Roomba 870 Side Brush Motor Replacement: adım 6, 3 resimden 1. iRobot Roomba 870 Side Brush Motor Replacement: adım 6, 3 resimden 2. iRobot Roomba 870 Side Brush Motor Replacement: adım 6, 3 resimden 3.
    • Remove the two 2.5mm screws in the inner motor housing using a Phillips #00 screwdriver.
    • After removing the two screws, the motor will slide right out the back, and it can be replaced.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Karthik Padmanabhan
164 İtibar
1 Kılavuz yazıldı
Cal Poly, Team S14-G3, Banghart Spring 2017 Cal Poly, Team S14-G3, Banghart Spring 2017 üyesi
CPSU-BANGHART-S17S14G3
4 Üyeler
10 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 54
Her zaman: 2,909
