Ana içeriğe geç
iRobot Roomba 880 Cleaning Head Replacement
Neye ihtiyacın var
  1. iRobot Roomba 880 Cleaning Head Replacement, Cleaning Head: adım 1, 3 resimden 1. iRobot Roomba 880 Cleaning Head Replacement, Cleaning Head: adım 1, 3 resimden 2. iRobot Roomba 880 Cleaning Head Replacement, Cleaning Head: adım 1, 3 resimden 3.
    • Flip the Roomba over, wheel-side up.
    • Using a Phillips #1 screwdriver, loosen the four 15 mm screws illustrated. Two are located on the battery door, while two are on the bottom panel.
    • Remove the battery door, pulling straight up from the two indents above the screws.
  2. iRobot Roomba 880 Cleaning Head Replacement, Side Brush: adım 2, 2 resimden 1. iRobot Roomba 880 Cleaning Head Replacement, Side Brush: adım 2, 2 resimden 2.
    • Using a flat head screwdriver, loosen the screw on the top of the side brush.
    • Remove side brush.
    • The bottom panel cannot be removed without first removing the side brush, so make sure to do this first.
  3. iRobot Roomba 880 Cleaning Head Replacement, Bottom Panel: adım 3, 1 resimden 1.
    • Pull up on the bottom panel to remove.
  4. iRobot Roomba 880 Cleaning Head Replacement, Dust Bin: adım 4, 2 resimden 1. iRobot Roomba 880 Cleaning Head Replacement, Dust Bin: adım 4, 2 resimden 2.
    • Reach underneath the dust bin, press the bin removal button, and pull out.
    • The bin removal button is located on the top edge of the bin.
  5. iRobot Roomba 880 Cleaning Head Replacement: adım 5, 2 resimden 1. iRobot Roomba 880 Cleaning Head Replacement: adım 5, 2 resimden 2.
    • Using a Phillips #1 screwdriver, remove the four 10 mm screws shown.
  6. iRobot Roomba 880 Cleaning Head Replacement, Remove Cleaning Head: adım 6, 3 resimden 1. iRobot Roomba 880 Cleaning Head Replacement, Remove Cleaning Head: adım 6, 3 resimden 2. iRobot Roomba 880 Cleaning Head Replacement, Remove Cleaning Head: adım 6, 3 resimden 3.
    • Remove the cleaning head by grabbing the two protruding tabs as shown, and pulling straight up.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Allie Ahern
130 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S17-G4, Banghart Spring 2017 Cal Poly, Team S17-G4, Banghart Spring 2017 üyesi
CPSU-BANGHART-S17S17G4
5 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 53
Her zaman: 2,633
