Ana içeriğe geç
iRobot Roomba 880 Side Brush Motor Replacement
Neye ihtiyacın var
  1. iRobot Roomba 880 Side Brush Motor Replacement, Side Brush Motor: adım 1, 3 resimden 1. iRobot Roomba 880 Side Brush Motor Replacement, Side Brush Motor: adım 1, 3 resimden 2. iRobot Roomba 880 Side Brush Motor Replacement, Side Brush Motor: adım 1, 3 resimden 3.
    • Remove the two Phillips #1 15mm screws holding the battery cover in place.
    • Once unscrewed, remove the battery cover and set aside.
  2. iRobot Roomba 880 Side Brush Motor Replacement: adım 2, 3 resimden 1. iRobot Roomba 880 Side Brush Motor Replacement: adım 2, 3 resimden 2. iRobot Roomba 880 Side Brush Motor Replacement: adım 2, 3 resimden 3.
    • Remove two 15mm Phillips #1 screws beneath each side wheel.
  3. iRobot Roomba 880 Side Brush Motor Replacement: adım 3, 3 resimden 1. iRobot Roomba 880 Side Brush Motor Replacement: adım 3, 3 resimden 2. iRobot Roomba 880 Side Brush Motor Replacement: adım 3, 3 resimden 3.
    • Remove the 10mm Phillips #1 screw holding the side brush in place.
    • Once unscrewed, remove the side brush and set aside.
  4. iRobot Roomba 880 Side Brush Motor Replacement: adım 4, 1 resimden 1.
    • Remove the outer covering.
  5. iRobot Roomba 880 Side Brush Motor Replacement: adım 5, 2 resimden 1. iRobot Roomba 880 Side Brush Motor Replacement: adım 5, 2 resimden 2.
    • Remove the three 10mm Phillips #1 screws holding down the side brush motor case.
  6. iRobot Roomba 880 Side Brush Motor Replacement: adım 6, 2 resimden 1. iRobot Roomba 880 Side Brush Motor Replacement: adım 6, 2 resimden 2.
    • Take out the side brush motor case.
  7. iRobot Roomba 880 Side Brush Motor Replacement: adım 7, 1 resimden 1.
    • Remove the 10mm Phillips #1 screw holding down the lid of the side brush motor case.
  8. iRobot Roomba 880 Side Brush Motor Replacement: adım 8, 3 resimden 1. iRobot Roomba 880 Side Brush Motor Replacement: adım 8, 3 resimden 2. iRobot Roomba 880 Side Brush Motor Replacement: adım 8, 3 resimden 3.
    • Remove the piece holding the lid to the case.
    • Take off the lid and set aside.
  9. iRobot Roomba 880 Side Brush Motor Replacement: adım 9, 2 resimden 1. iRobot Roomba 880 Side Brush Motor Replacement: adım 9, 2 resimden 2.
    • Remove the three 10mm Phillips #1 screws.
  10. iRobot Roomba 880 Side Brush Motor Replacement: adım 10, 3 resimden 1. iRobot Roomba 880 Side Brush Motor Replacement: adım 10, 3 resimden 2. iRobot Roomba 880 Side Brush Motor Replacement: adım 10, 3 resimden 3.
    • Flip over and remove the side brush motor.
    • All done!
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
agriewe
155 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S17-G4, Banghart Spring 2017 Cal Poly, Team S17-G4, Banghart Spring 2017 üyesi
CPSU-BANGHART-S17S17G4
5 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 21
Her zaman: 1,571
