Ana içeriğe geç
iRobot Roomba 890 Cleaning Head Replacement
Neye ihtiyacın var
  1. iRobot Roomba 890 Cleaning Head Replacement, Cleaning Head: adım 1, 1 resimden 1.
    • Use a Phillips #2 screwdriver to remove the two 11 mm screws.
    • Remove the battery cover.
  2. iRobot Roomba 890 Cleaning Head Replacement: adım 2, 2 resimden 1. iRobot Roomba 890 Cleaning Head Replacement: adım 2, 2 resimden 2.
    • Remove the battery by pulling directly up on the grey pull tabs.
  3. iRobot Roomba 890 Cleaning Head Replacement: adım 3, 2 resimden 1. iRobot Roomba 890 Cleaning Head Replacement: adım 3, 2 resimden 2.
    • Use a Phillips #2 screwdriver to remove the one 7.7 mm screw.
    • Remove the yellow brush head.
  4. iRobot Roomba 890 Cleaning Head Replacement: adım 4, 3 resimden 1. iRobot Roomba 890 Cleaning Head Replacement: adım 4, 3 resimden 2. iRobot Roomba 890 Cleaning Head Replacement: adım 4, 3 resimden 3.
    • Lift the baseplate up and off.
  5. iRobot Roomba 890 Cleaning Head Replacement: adım 5, 2 resimden 1. iRobot Roomba 890 Cleaning Head Replacement: adım 5, 2 resimden 2.
    • To remove the dust collection bin, press the release button on the top side of the Roomba and pull it straight out.
  6. iRobot Roomba 890 Cleaning Head Replacement: adım 6, 3 resimden 1. iRobot Roomba 890 Cleaning Head Replacement: adım 6, 3 resimden 2. iRobot Roomba 890 Cleaning Head Replacement: adım 6, 3 resimden 3.
    • Press the bright yellow tabs inwards and lift up at the same time to expose the cleaning head.
    • Remove the main brushes by lifting them up and out of the housing.
  7. iRobot Roomba 890 Cleaning Head Replacement: adım 7, 3 resimden 1. iRobot Roomba 890 Cleaning Head Replacement: adım 7, 3 resimden 2. iRobot Roomba 890 Cleaning Head Replacement: adım 7, 3 resimden 3.
    • Lift the cleaning head out of the Roomba.
Sonuç
Caeden Foxhoven
331 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-3, Petersen Spring 2022 UMass Dartmouth, Team 1-3, Petersen Spring 2022 üyesi
UMASSD-PETERSEN-S22S1G3
3 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 22
Her zaman: 524
