Ana içeriğe geç
iRobot Roomba 890 Motorized Wheel Module Replacement
Neye ihtiyacın var
    1. iRobot Roomba 890 Motorized Wheel Module Replacement, Motorized Wheel Module: adım 1, 2 resimden 1. iRobot Roomba 890 Motorized Wheel Module Replacement, Motorized Wheel Module: adım 1, 2 resimden 2.
      • Use a Phillips #2 screwdriver to remove the 7.7 mm screw securing the side brush-head.
      • Remove the yellow brush head.
      FixBot'a Sor
      Yorum Ekle
    2. iRobot Roomba 890 Motorized Wheel Module Replacement: adım 2, 1 resimden 1.
      • Place the Roomba with its bottom facing toward you.
      • Use a Phillips #2 screwdriver to remove the four 11 mm screws.
      FixBot'a Sor
      Yorum Ekle
    3. iRobot Roomba 890 Motorized Wheel Module Replacement: adım 3, 2 resimden 1. iRobot Roomba 890 Motorized Wheel Module Replacement: adım 3, 2 resimden 2.
      • Remove the battery by pulling directly up on the grey pull tabs.
      FixBot'a Sor
      Yorum Ekle
    4. iRobot Roomba 890 Motorized Wheel Module Replacement: adım 4, 1 resimden 1.
      • Lift off the baseplate.
      FixBot'a Sor
      Yorum Ekle
    5. iRobot Roomba 890 Motorized Wheel Module Replacement: adım 5, 2 resimden 1. iRobot Roomba 890 Motorized Wheel Module Replacement: adım 5, 2 resimden 2.
      • Remove the collection bin by pressing the release button on the top side of the Roomba and pulling straight out.
      FixBot'a Sor
      Yorum Ekle
    6. iRobot Roomba 890 Motorized Wheel Module Replacement: adım 6, 2 resimden 1. iRobot Roomba 890 Motorized Wheel Module Replacement: adım 6, 2 resimden 2.
      • On the underside of the Roomba, use a Phillips #1 screwdriver to remove the three 15.5 mm screws.
      FixBot'a Sor
      Yorum Ekle
    7. iRobot Roomba 890 Motorized Wheel Module Replacement: adım 7, 1 resimden 1.
      • Grip both sides of the casing and pull it straight out.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Dustin Staples
339 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-3, Petersen Spring 2022 UMass Dartmouth, Team 1-3, Petersen Spring 2022 üyesi
UMASSD-PETERSEN-S22S1G3
3 Üyeler
32 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 44
Her zaman: 1,107
