Ana içeriğe geç
iRobot Roomba 890 Motorized Wheel Module Replacement
Neye ihtiyacın var
  1. iRobot Roomba 890 Motorized Wheel Module Replacement, Motorized Wheel Module: adım 1, 2 resimden 1. iRobot Roomba 890 Motorized Wheel Module Replacement, Motorized Wheel Module: adım 1, 2 resimden 2.
    • Use a Phillips #2 screwdriver to remove the 7.7 mm screw securing the side brush-head.
    • Remove the yellow brush head.
  2. iRobot Roomba 890 Motorized Wheel Module Replacement: adım 2, 1 resimden 1.
    • Place the Roomba with its bottom facing toward you.
    • Use a Phillips #2 screwdriver to remove the four 11 mm screws.
  3. iRobot Roomba 890 Motorized Wheel Module Replacement: adım 3, 2 resimden 1. iRobot Roomba 890 Motorized Wheel Module Replacement: adım 3, 2 resimden 2.
    • Remove the battery by pulling directly up on the grey pull tabs.
  4. iRobot Roomba 890 Motorized Wheel Module Replacement: adım 4, 1 resimden 1.
    • Lift off the baseplate.
  5. iRobot Roomba 890 Motorized Wheel Module Replacement: adım 5, 2 resimden 1. iRobot Roomba 890 Motorized Wheel Module Replacement: adım 5, 2 resimden 2.
    • Remove the collection bin by pressing the release button on the top side of the Roomba and pulling straight out.
  6. iRobot Roomba 890 Motorized Wheel Module Replacement: adım 6, 2 resimden 1. iRobot Roomba 890 Motorized Wheel Module Replacement: adım 6, 2 resimden 2.
    • On the underside of the Roomba, use a Phillips #1 screwdriver to remove the three 15.5 mm screws.
  7. iRobot Roomba 890 Motorized Wheel Module Replacement: adım 7, 1 resimden 1.
    • Grip both sides of the casing and pull it straight out.
Sonuç
Dustin Staples
339 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-3, Petersen Spring 2022 UMass Dartmouth, Team 1-3, Petersen Spring 2022 üyesi
UMASSD-PETERSEN-S22S1G3
3 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 31
Her zaman: 824
