Ana içeriğe geç
iRobot Roomba 891 Battery Replacement
Neye ihtiyacın var
  1. iRobot Roomba 891 Battery Replacement, Battery: adım 1, 2 resimden 1. iRobot Roomba 891 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Start by flipping your Roomba onto its back on a flat surface.
    • Be sure not to close the side brush bristles in the battery door during reassembly as shown by the handy warning in the second photo.
  2. iRobot Roomba 891 Battery Replacement: adım 2, 1 resimden 1.
    • Unscrew both the 11mm Phillips #2 screws from the battery cover and remove cover from the Roomba.
    • These captive screws are not intended to be removed from the cover.
  3. iRobot Roomba 891 Battery Replacement: adım 3, 3 resimden 1. iRobot Roomba 891 Battery Replacement: adım 3, 3 resimden 2. iRobot Roomba 891 Battery Replacement: adım 3, 3 resimden 3.
    • Grasp the tabs on either side of the battery.
    • Remove the battery by pulling up on the tabs.
    • While you're here, check the battery contacts for corrosion or debris.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
justin i added a push pin to step 1
thomas Wilson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 15
Her zaman: 822
