Ana içeriğe geç
iRobot Roomba 960 Filter Replacement
Neye ihtiyacın var
  1. iRobot Roomba 960 Filter Replacement, Filter: adım 1, 1 resimden 1.
    • Orient the Roomba so that the device is on its wheels and the words can be read from left to right.
  2. iRobot Roomba 960 Filter Replacement: adım 2, 3 resimden 1. iRobot Roomba 960 Filter Replacement: adım 2, 3 resimden 2. iRobot Roomba 960 Filter Replacement: adım 2, 3 resimden 3.
    • Press the large button on the Roomba that is located closest to you.
    • Pull to remove the dust bin.
  3. iRobot Roomba 960 Filter Replacement: adım 3, 3 resimden 1. iRobot Roomba 960 Filter Replacement: adım 3, 3 resimden 2. iRobot Roomba 960 Filter Replacement: adım 3, 3 resimden 3.
    • With the dust bin completely detached from the Roomba, press the tab that is located on your right (there is a yellow arrow pointing to it).
    • Lift the red plastic cover to access the filter.
  4. iRobot Roomba 960 Filter Replacement: adım 4, 3 resimden 1. iRobot Roomba 960 Filter Replacement: adım 4, 3 resimden 2. iRobot Roomba 960 Filter Replacement: adım 4, 3 resimden 3.
    • Using the yellow ribbon that is located at the top of the filter, pull it towards you.
    • Carefully remove the used filter.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Vanessa Greyson
471 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-3, Blackwell Spring 2017 USF Tampa, Team 16-3, Blackwell Spring 2017 üyesi
USFT-BLACKWELL-S17S16G3
4 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
I need to replace the red bin cover over the filter, do I need to unscrew the black piece or something or just try to pry it out. I don’t want to break it.
Sandra Freed - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 21
Her zaman: 2,170
