Ana içeriğe geç
iRobot Roomba 980 Brush Module Replacement
Neye ihtiyacın var
  1. iRobot Roomba 980 Brush Module Replacement, Battery: adım 1, 1 resimden 1.
    • Flip over the device and remove the two 11.5 mm screws using the Phillips #1 screwdriver.
  2. iRobot Roomba 980 Brush Module Replacement: adım 2, 2 resimden 1. iRobot Roomba 980 Brush Module Replacement: adım 2, 2 resimden 2.
    • Unscrew the back plate using a Phillips #1 screwdriver.
    • Carefully lift the panel up once the screws are removed.
  3. iRobot Roomba 980 Brush Module Replacement: adım 3, 2 resimden 1. iRobot Roomba 980 Brush Module Replacement: adım 3, 2 resimden 2.
    • With both hands, grab the two black tabs on each end of the battery.
    • Pull the tabs upwards to remove the battery.
  4. iRobot Roomba 980 Brush Module Replacement, Brush Module: adım 4, 3 resimden 1. iRobot Roomba 980 Brush Module Replacement, Brush Module: adım 4, 3 resimden 2. iRobot Roomba 980 Brush Module Replacement, Brush Module: adım 4, 3 resimden 3.
    • Press down on the button on the rear of the device.
    • Pull bin towards you to remove it.
  5. iRobot Roomba 980 Brush Module Replacement: adım 5, 2 resimden 1. iRobot Roomba 980 Brush Module Replacement: adım 5, 2 resimden 2.
    • Loosen the screw holding the side brush in place.
    • The screw is attached to the side brush and does not come out completely.
    • Lift the side brush.
  6. iRobot Roomba 980 Brush Module Replacement: adım 6, 2 resimden 1. iRobot Roomba 980 Brush Module Replacement: adım 6, 2 resimden 2.
    • Remove the (2) 11.5mm Phillips #1 screws holding down the bottom plate.
    • Carefully lift the bottom plate.
  7. iRobot Roomba 980 Brush Module Replacement: adım 7, 1 resimden 1.
    • Remove the (4) 15.8mm Phillips #1 gold screws around the brush module.
  8. iRobot Roomba 980 Brush Module Replacement: adım 8, 2 resimden 1. iRobot Roomba 980 Brush Module Replacement: adım 8, 2 resimden 2.
    • Lift the brush module carefully using both hands.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Ernesto Rodriguez Romero
1.040 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S14-G2, Boczar Fall 2017 USF Tampa, Team S14-G2, Boczar Fall 2017 üyesi
USFT-BOCZAR-F17S14G2
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 38
Her zaman: 4,988
