Ana içeriğe geç
iRobot Roomba 980 Rear Wheels
Neye ihtiyacın var
  1. iRobot Roomba 980 Rear Wheels, Battery: adım 1, 1 resimden 1.
    • Flip over the device and remove the two 11.5 mm screws using the Phillips #1 screwdriver.
  2. iRobot Roomba 980 Rear Wheels: adım 2, 2 resimden 1. iRobot Roomba 980 Rear Wheels: adım 2, 2 resimden 2.
    • Unscrew the back plate using a Phillips #1 screwdriver.
    • Carefully lift the panel up once the screws are removed.
  3. iRobot Roomba 980 Rear Wheels: adım 3, 2 resimden 1. iRobot Roomba 980 Rear Wheels: adım 3, 2 resimden 2.
    • With both hands, grab the two black tabs on each end of the battery.
    • Pull the tabs upwards to remove the battery.
  4. iRobot Roomba 980 Rear Wheels, Rear Wheels: adım 4, 2 resimden 1. iRobot Roomba 980 Rear Wheels, Rear Wheels: adım 4, 2 resimden 2.
    • Loosen the screw on the side brush.
    • Lift the side brush from the device.
  5. iRobot Roomba 980 Rear Wheels: adım 5, 2 resimden 1. iRobot Roomba 980 Rear Wheels: adım 5, 2 resimden 2.
    • Unscrew the (2) 11.5mm screws using the Phillips #1 screwdriver.
    • Carefully remove the plate by lifting it off of the device.
  6. iRobot Roomba 980 Rear Wheels: adım 6, 2 resimden 1. iRobot Roomba 980 Rear Wheels: adım 6, 2 resimden 2.
    • Removing the brush module may ease the removal of the wheel module
    • Locate the (3) 15.8mm gold Phillips #1 screws and unscrew them.
    • Lift the wheel module removing it from the vacuum.
    • Remove the other wheel by repeating these steps.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Ernesto Rodriguez Romero
971 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S14-G2, Boczar Fall 2017 USF Tampa, Team S14-G2, Boczar Fall 2017 üyesi
USFT-BOCZAR-F17S14G2
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 17
Her zaman: 3,205
