Ana içeriğe geç
iRobot Roomba Edge-Sweeping Brush Replacement
Neye ihtiyacın var
  1. iRobot Roomba Edge-Sweeping Brush Replacement, Loosen the edge brush screw: adım 1, 1 resimden 1.
    • Make sure your Roomba is turned off and flip it over to access its underside.
    • Use a Phillips screwdriver to loosen the single captive screw securing the edge-sweeping brush. Make sure to keep the brush from rotating while screwing.
    • This screw is a captive screw and therefore not removable.
  2. iRobot Roomba Edge-Sweeping Brush Replacement, Remove the edge brush: adım 2, 2 resimden 1. iRobot Roomba Edge-Sweeping Brush Replacement, Remove the edge brush: adım 2, 2 resimden 2.
    • Use your fingers to gather all three brush arms and grab them simultaneously.
    • Steadily pull upwards to release the brush from its hexagonal axle. You can gently rock it back and forth if it sits too tight.
Sonuç
Tobias Isakeit
129.422 İtibar
189 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 22
Son 30 gün: 103
Her zaman: 2,196
