Ana içeriğe geç
iRobot Roomba e5 Caster Wheel Replacement
Neye ihtiyacın var
  1. iRobot Roomba e5 Caster Wheel Replacement, Caster Wheel: adım 1, 2 resimden 1. iRobot Roomba e5 Caster Wheel Replacement, Caster Wheel: adım 1, 2 resimden 2.
    • Use an opening tool to pry beneath the grey ring on each side of the wheel until it pops out.
    FixBot'a Sor
    Yorum Ekle
  2. iRobot Roomba e5 Caster Wheel Replacement: adım 2, 2 resimden 1. iRobot Roomba e5 Caster Wheel Replacement: adım 2, 2 resimden 2.
    • Pull the wheel out of the vacuum.
    • Dirt and debris can be caught under the wheel and may lead to decreased mobility. Try cleaning out the debris before replacing the wheel.
    FixBot'a Sor
    Yorum Ekle
  3. iRobot Roomba e5 Caster Wheel Replacement: adım 3, 3 resimden 1. iRobot Roomba e5 Caster Wheel Replacement: adım 3, 3 resimden 2. iRobot Roomba e5 Caster Wheel Replacement: adım 3, 3 resimden 3.
    • Remove two 10 mm screws from the wheel housing using a Phillips #1 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. iRobot Roomba e5 Caster Wheel Replacement: adım 4, 1 resimden 1.
    • Pull the wheel housing out of the vacuum.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kyle Christensen
432 İtibar
3 adet Kılavuz yazıldı
Ekip
Casper College, Team 1-2, Lareau Spring 2022 Casper College, Team 1-2, Lareau Spring 2022 üyesi
CASC-LAREAU-S22S1G2
4 Üyeler
19 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 43
Her zaman: 1,054
