Ana içeriğe geç
iRobot Roomba i3 Plus Battery Replacement
Neye ihtiyacın var
  1. iRobot Roomba i3 Plus Battery Replacement, The Cover: adım 1, 1 resimden 1.
    • Unscrew the 5 #0 Phillips screws.
    • The screws do not come out all the way, they will stay in the cover.
  2. iRobot Roomba i3 Plus Battery Replacement, The Brush: adım 2, 1 resimden 1.
    • Use a Flathead screwdriver or Philips to unscrew the side brush.
    • Make sure to hold the side brush or it will spin when you try to unscrew it.
  3. iRobot Roomba i3 Plus Battery Replacement, Remove cover: adım 3, 1 resimden 1.
    • Gently pull the side brush straight up.
    • Do not pull the side brush too hard or you may break the plastic.
  4. iRobot Roomba i3 Plus Battery Replacement: adım 4, 1 resimden 1.
    • Use your fingernails to pull up on each side to remove the cover.
    • If there is resistance, Do not pull hard, just find what screw is not all the way unscrewed.
  5. iRobot Roomba i3 Plus Battery Replacement: adım 5, 1 resimden 1.
    • Pull back the clip in the middle and pull the battery straight up.
    • When assembling the Roomba again. put the robot on its charging base to wake it up.
  6. iRobot Roomba i3 Plus Battery Replacement: adım 6, 1 resimden 1.
    • Line the battery up with the notches and side it in.
Sonuç
To reassemble your Roomba, follow these instructions in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
Hunter Platt
183 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 23
Her zaman: 387
