Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
Is your iRobot Roomba i7, not charging when connected to the Home Base? Is your device not turning on? In order to fix this problem, you must remove and replace the battery in your device. This guide will help you replace the battery on your iRobot Roomba i7.
The battery for the iRobot Roomba i7 is located in the the center of the device, directly in front of the iRobot Roomba i7 dual roller rubber brush system. The function of the battery is to store, and provide electricity to the entire device. The average run time of the iRobot Roomba i7 is 1 hour and 15 minutes.
Before you begin using this guide, make sure that your Roomba is turned off, and disconnected from the charging station, or Home Base.
Warning: Swollen or cracked batteries can be hazardous to humans due to fumes or potential fire. If you feel unsafe at anytime completing this guide, put your device in a fireproof container and take it to a replacement professional.
Parçalar
Hiçbir parça belirtilmedi.
  1. Warning: Swollen or cracked batteries can be hazardous to humans  due to fumes or potential fire. If you feel unsafe at anytime completing this guide, put your device in a fireproof container and take it to a replacement professional. Flip the iRobot Roomba i7 so that the underside is facing upwards. Using a Phillips #1 screwdriver, loosen the following screws:
    • Warning: Swollen or cracked batteries can be hazardous to humans due to fumes or potential fire. If you feel unsafe at anytime completing this guide, put your device in a fireproof container and take it to a replacement professional.
    • Flip the iRobot Roomba i7 so that the underside is facing upwards.
    • Using a Phillips #1 screwdriver, loosen the following screws:
    • 6.27mm-screw in the center of the side brush.
    • Five 6.24mm-screws on the bottom cover.
  2. Carefully remove the bottom cover.
    • Carefully remove the bottom cover.
    • If the cover is stuck or hard to remove, use a prying tool to separate it from the device.
  3. Before removing the battery, make sure that it is not hot or swollen. Swollen lithium-ion batteries release gases that are hazardous for humans. Unclip the original battery and pull upwards to remove it.
    • Before removing the battery, make sure that it is not hot or swollen. Swollen lithium-ion batteries release gases that are hazardous for humans.
    • Unclip the original battery and pull upwards to remove it.
    • Use a prying tool if necessary.
Sonuç
Battery Disposal: Never dispose of old batteries in the trash. For proper disposal, take it to your local battery recycling facility. You can find one by doing a quick internet search for "battery recycling facility" and including your zip/postal code or city name in the search. Also, check out http://call2recycle.org and plug in your zip/postal code. This will show you all of the registered drop-off locations near you.
Bir Yorum
Its a shame the battery is so small compared to the cavity. The run time could be greatly expanded by simply putting in a larger battery.
Reid Kersey - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 58
Son 30 gün: 262
Her zaman: 1,754
