Ana içeriğe geç
iRobot Looj 120 Controller Buttons Replacement
Neye ihtiyacın var
  1. iRobot Looj 120 Controller Buttons Replacement, Removing Screws: adım 1, 1 resimden 1.
    • Remove the four exterior screws located under controller and on the handle.
    • Remove the five screws shown, and then carefully remove top plate. Electrical components are attached to top plate.
  2. iRobot Looj 120 Controller Buttons Replacement, Locate Circuitry: adım 2, 1 resimden 1.
    • Disconnect circuit board from power leads, and install new circuit board.
  3. iRobot Looj 120 Controller Buttons Replacement, Remove Exterior Screws: adım 3, 1 resimden 1.
    • Remove the four exterior screws to gain access to inner components. These screws are located on the bottom of the controller and on the handle.
    • Remove the five interior screws to access the buttons.
  4. iRobot Looj 120 Controller Buttons Replacement, Accessing the Buttons: adım 4, 1 resimden 1.
    • Remove top plate carefully so that none of the electrical components are damaged.
    • Remove the broken button and insert the new button into the mounting hole.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Lucas Otto
101 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-5, Duarte Fall 2014 UMass Dartmouth, Team 2-5, Duarte Fall 2014 üyesi
UMASSD-DUARTE-F14S2G5
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 216
