Giriş
For this guide you will be removing rear wheels, then removing the outer shell and then replacing the motor.
Neye ihtiyacın var
Bir Yorum
Yeah, to replace the motor just 4 screws and no parts required! Too easy, too easy to write an article that doesn’t help :( Is it just to sell a screwdriver? This would not improve your reputation. You’re wasting our time and wasting your time.
Description: Remove the 4 screws than anyone can see is a good start but did anyone been able to actualy open the body and access inside the box?
I do have an iRobot Looj 330. The body looks very similar to the other model in the range. There are 4 screws, yes but the body in 2 parts doesn’t open that easy. It’s waterproof, I believe there is a trick… Which?
