Ana içeriğe geç
iVIEW-754TPC Battery Replacement
Neye ihtiyacın var
  1. iVIEW-754TPC Battery Replacement, Rear Panel: adım 1, 3 resimden 1. iVIEW-754TPC Battery Replacement, Rear Panel: adım 1, 3 resimden 2. iVIEW-754TPC Battery Replacement, Rear Panel: adım 1, 3 resimden 3.
    • Before disassembling your tablet, make sure it is powered off.
    • Use plastic opening tool to release the clips holding the device together. The clips will take a small amount of pressure to release. Once you have the plastic opening tool inserted, use a twisting action to release the clips. Start from bottom of device and work all the way around.
  2. iVIEW-754TPC Battery Replacement, Remove Battery: adım 2, 3 resimden 1. iVIEW-754TPC Battery Replacement, Remove Battery: adım 2, 3 resimden 2. iVIEW-754TPC Battery Replacement, Remove Battery: adım 2, 3 resimden 3.
    • Use flat side of the spudger to get under battery and use pressure to release from glue. Do this all the way around battery until it comes off.
    • At this point do not attempt to fully remove the battery as it is still attached to the logic board.
  3. iVIEW-754TPC Battery Replacement, Desolder wires: adım 3, 3 resimden 1. iVIEW-754TPC Battery Replacement, Desolder wires: adım 3, 3 resimden 2. iVIEW-754TPC Battery Replacement, Desolder wires: adım 3, 3 resimden 3.
    • Once battery is off, the wires will still be connected to motherboard. You will need to desolder the wires.
    • Using the soldering tool, use the heat to melt the connection. As you do this, pull on the wires with a tweezer until wires comes off.
    • To ease reassembly, take note of which wire goes to the negative and positive terminals.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
calvin
188 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 5-4, Brown Winter 2015 USF Tampa, Team 5-4, Brown Winter 2015 üyesi
USFT-BROWN-W15S5G4
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 2,401
