Ana içeriğe geç
iVIEW-754TPC Camera Assembly Replacement
Neye ihtiyacın var
    1. iVIEW-754TPC Camera Assembly Replacement, Rear Panel: adım 1, 3 resimden 1. iVIEW-754TPC Camera Assembly Replacement, Rear Panel: adım 1, 3 resimden 2. iVIEW-754TPC Camera Assembly Replacement, Rear Panel: adım 1, 3 resimden 3.
      • Before disassembling your tablet, make sure it is powered off.
      • Use plastic opening tool to release the clips holding the device together. The clips will take a small amount of pressure to release. Once you have the plastic opening tool inserted, use a twisting action to release the clips. Start from bottom of device and work all the way around.
      FixBot'a Sor
      Yorum Ekle
    1. iVIEW-754TPC Camera Assembly Replacement, Camera Assembly: adım 2, 3 resimden 1. iVIEW-754TPC Camera Assembly Replacement, Camera Assembly: adım 2, 3 resimden 2. iVIEW-754TPC Camera Assembly Replacement, Camera Assembly: adım 2, 3 resimden 3.
      Bu adımda kullanılan alet:
      • The camera module is located directly under the top right corner of the back cover.
      • Peel back the tape holding down the camera ribbon connector using a pair of tweezers.
      • As you peel the tape backward, the front facing camera may come out, this is not an issue.
      • If the front facing camera does not come out, gently lift it out with a pair of tweezers
      FixBot'a Sor
      Yorum Ekle
    2. iVIEW-754TPC Camera Assembly Replacement, Remove Camera: adım 3, 2 resimden 1. iVIEW-754TPC Camera Assembly Replacement, Remove Camera: adım 3, 2 resimden 2.
      • Use a spudger to lift flap on top of the camera ZIF adapter.
      • At this point the camera module can be easily removed with a pair of tweezers.
      • During reassembly, make sure you put the ZIF adapter snugly back into its socket and secure the flap.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Robert Clark
1.065 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 5-4, Brown Winter 2015 USF Tampa, Team 5-4, Brown Winter 2015 üyesi
USFT-BROWN-W15S5G4
4 Üyeler
48 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 15
Son 30 gün: 34
Her zaman: 527
