Ana içeriğe geç
iVIEW-754TPC Digitizer Replacement
Neye ihtiyacın var
    1. iVIEW-754TPC Digitizer Replacement, Rear Panel: adım 1, 3 resimden 1. iVIEW-754TPC Digitizer Replacement, Rear Panel: adım 1, 3 resimden 2. iVIEW-754TPC Digitizer Replacement, Rear Panel: adım 1, 3 resimden 3.
      • Before disassembling your tablet, make sure it is powered off.
      • Use plastic opening tool to release the clips holding the device together. The clips will take a small amount of pressure to release. Once you have the plastic opening tool inserted, use a twisting action to release the clips. Start from bottom of device and work all the way around.
      FixBot'a Sor
      Yorum Ekle
    1. iVIEW-754TPC Digitizer Replacement, Remove Battery: adım 2, 3 resimden 1. iVIEW-754TPC Digitizer Replacement, Remove Battery: adım 2, 3 resimden 2. iVIEW-754TPC Digitizer Replacement, Remove Battery: adım 2, 3 resimden 3.
      • Use flat side of the spudger to get under battery and use pressure to release from glue. Do this all the way around battery until it comes off.
      • At this point do not attempt to fully remove the battery as it is still attached to the logic board.
      FixBot'a Sor
      Yorum Ekle
    1. iVIEW-754TPC Digitizer Replacement, Camera Assembly: adım 3, 3 resimden 1. iVIEW-754TPC Digitizer Replacement, Camera Assembly: adım 3, 3 resimden 2. iVIEW-754TPC Digitizer Replacement, Camera Assembly: adım 3, 3 resimden 3.
      Bu adımda kullanılan alet:
      • The camera module is located directly under the top right corner of the back cover.
      • Peel back the tape holding down the camera ribbon connector using a pair of tweezers.
      • As you peel the tape backward, the front facing camera may come out, this is not an issue.
      • If the front facing camera does not come out, gently lift it out with a pair of tweezers
      FixBot'a Sor
      Yorum Ekle
    2. iVIEW-754TPC Digitizer Replacement, Remove Camera: adım 4, 2 resimden 1. iVIEW-754TPC Digitizer Replacement, Remove Camera: adım 4, 2 resimden 2.
      • Use a spudger to lift flap on top of the camera ZIF adapter.
      • At this point the camera module can be easily removed with a pair of tweezers.
      • During reassembly, make sure you put the ZIF adapter snugly back into its socket and secure the flap.
      FixBot'a Sor
      Yorum Ekle
    1. iVIEW-754TPC Digitizer Replacement, Logic Board: adım 5, 1 resimden 1.
      • Remove the four 2.2mm Phillips screws holding the logic board in place. Place the screws on the iFixit magnetic project mat.
      FixBot'a Sor
      Yorum Ekle
    2. iVIEW-754TPC Digitizer Replacement, WIFI Antenna: adım 6, 2 resimden 1. iVIEW-754TPC Digitizer Replacement, WIFI Antenna: adım 6, 2 resimden 2.
      • Gently peel the WIFI Antenna up using a pair of tweezers.
      FixBot'a Sor
      Yorum Ekle
    3. iVIEW-754TPC Digitizer Replacement, Disconnect LCD: adım 7, 3 resimden 1. iVIEW-754TPC Digitizer Replacement, Disconnect LCD: adım 7, 3 resimden 2. iVIEW-754TPC Digitizer Replacement, Disconnect LCD: adım 7, 3 resimden 3.
      • Use a spudger to lift the flap on top of the LCD ZIF socket.
      • Gently remove the ribbon cable from the socket using a tweezers.
      FixBot'a Sor
      Yorum Ekle
    4. iVIEW-754TPC Digitizer Replacement, Disconnect Digitizer: adım 8, 3 resimden 1. iVIEW-754TPC Digitizer Replacement, Disconnect Digitizer: adım 8, 3 resimden 2. iVIEW-754TPC Digitizer Replacement, Disconnect Digitizer: adım 8, 3 resimden 3.
      • Use a spudger to lift the flap on top of the digitizer ZIF socket.
      • Gently pull the tape attached to the ribbon cable to remove the cable from its socket.
      FixBot'a Sor
      Yorum Ekle
    5. iVIEW-754TPC Digitizer Replacement, Remove Logic Board: adım 9, 3 resimden 1. iVIEW-754TPC Digitizer Replacement, Remove Logic Board: adım 9, 3 resimden 2. iVIEW-754TPC Digitizer Replacement, Remove Logic Board: adım 9, 3 resimden 3.
      • Gently slide the spudger below the logic board at the left side nearest the battery. Lift upward and away from the power button and bottom connectors.
      • The battery is still attached to the logic board. Be careful to not tear the two apart during removal.
      FixBot'a Sor
      Yorum Ekle
    1. iVIEW-754TPC Digitizer Replacement, LCD: adım 10, 3 resimden 1. iVIEW-754TPC Digitizer Replacement, LCD: adım 10, 3 resimden 2. iVIEW-754TPC Digitizer Replacement, LCD: adım 10, 3 resimden 3.
      • Insert a plastic opening tool between the LCD and digitizer on the side of the LCD with the ribbon cable. Use a second plastic opening tool to lift the LCD from the digitizer. Repeat this process on both sides of the LCD ribbon cable.
      • Fully remove the LCD from the digitizer.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Robert Clark
1.065 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 5-4, Brown Winter 2015 USF Tampa, Team 5-4, Brown Winter 2015 üyesi
USFT-BROWN-W15S5G4
4 Üyeler
48 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 25
Her zaman: 1,379
