Ana içeriğe geç
iVIEW-754TPC Speaker Replacement
Neye ihtiyacın var
    1. iVIEW-754TPC Speaker Replacement, Rear Panel: adım 1, 3 resimden 1. iVIEW-754TPC Speaker Replacement, Rear Panel: adım 1, 3 resimden 2. iVIEW-754TPC Speaker Replacement, Rear Panel: adım 1, 3 resimden 3.
      • Before disassembling your tablet, make sure it is powered off.
      • Use plastic opening tool to release the clips holding the device together. The clips will take a small amount of pressure to release. Once you have the plastic opening tool inserted, use a twisting action to release the clips. Start from bottom of device and work all the way around.
      FixBot'a Sor
      Yorum Ekle
    1. iVIEW-754TPC Speaker Replacement, Desoldier speaker wires: adım 2, 3 resimden 1. iVIEW-754TPC Speaker Replacement, Desoldier speaker wires: adım 2, 3 resimden 2. iVIEW-754TPC Speaker Replacement, Desoldier speaker wires: adım 2, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Desoldier wires from the mother board. Use soldier iron to disconnect wires from mother board. Use tweezers to pull wires as the iron is heating.
      • Remove yellow tape from the speakers and use tweezers to pull speaker out.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Robert Clark
1.065 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 5-4, Brown Winter 2015 USF Tampa, Team 5-4, Brown Winter 2015 üyesi
USFT-BROWN-W15S5G4
4 Üyeler
48 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 23
Her zaman: 471
