Ana içeriğe geç
iView-776TPCII Rear Panel Replacement
Neye ihtiyacın var
    1. iView-776TPCII Rear Panel Replacement, Rear Panel: adım 1, 3 resimden 1. iView-776TPCII Rear Panel Replacement, Rear Panel: adım 1, 3 resimden 2. iView-776TPCII Rear Panel Replacement, Rear Panel: adım 1, 3 resimden 3.
      • Before disassembling your device, make sure that the power is completely turned off.
      • Use the plastic opening tool to release the clips holding the rear panel of the device onto the front section.
      • The clips may take some pressure before releasing.
      • Continue around the entire device until all of the clips have been released.
      FixBot'a Sor
      Yorum Ekle
    2. iView-776TPCII Rear Panel Replacement: adım 2, 2 resimden 1. iView-776TPCII Rear Panel Replacement: adım 2, 2 resimden 2.
      • Use a spudger to carefully free the speaker from it's housing on the back panel.
      • Place the spudger between the speaker and the rear panel. Use a prying motion to remove the component.
      • Be careful not to apply an over amount of force. If care is not taken, the speaker could break under the pressure.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ekip
IUPUI, Team 2-2, Baechle Fall 2015 IUPUI, Team 2-2, Baechle Fall 2015 üyesi
IUPUI-BAECHLE-F15S2G2
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 45
Her zaman: 790
