Ana içeriğe geç
ionvac SmartClean V2 Motor Wheel Replacement
Neye ihtiyacın var
    1. ionvac SmartClean V2 Motor Wheel Replacement, Shell (Top & Bottom): adım 1, 2 resimden 1. ionvac SmartClean V2 Motor Wheel Replacement, Shell (Top & Bottom): adım 1, 2 resimden 2.
      • Caution: Before beginning, turn off the ionvac and place it on a level surface.
      • Keep in mind that your ionvac has many small screws that can be easily lost. Using a magnetic project mat is best to prevent misplacing any parts.
      • Flip your ionvac right-side up, turning it so that the front filter vents are facing forward and the power button is furthest from you.
      FixBot'a Sor
      Yorum Ekle
    2. ionvac SmartClean V2 Motor Wheel Replacement: adım 2, 3 resimden 1. ionvac SmartClean V2 Motor Wheel Replacement: adım 2, 3 resimden 2. ionvac SmartClean V2 Motor Wheel Replacement: adım 2, 3 resimden 3.
      • Use a Phillips screwdriver to remove the 8 screws indicated in red holding the base together.
      • Use the same screwdriver to remove the 8 screws indicated in orange which hold the rims (bumper arms).
      • Remove the rims from your ionvac and set them aside.
      FixBot'a Sor
      Yorum Ekle
    3. ionvac SmartClean V2 Motor Wheel Replacement: adım 3, 1 resimden 1.
      • Flip your ionvac right-side up and tilt it upwards at a 45 degree angle.
      • Use a Jimmy or prying tool to wedge the sharp end through the bottom crevice (below the sensors).
      • Continue prying the outside rim of your ionvac open. You will feel the top shell (frame or cover) loosen.
      • Caution: Resist the urge to tear the top shell open until the entire rim has been loosened.
      FixBot'a Sor
      Yorum Ekle
    4. ionvac SmartClean V2 Motor Wheel Replacement: adım 4, 2 resimden 1. ionvac SmartClean V2 Motor Wheel Replacement: adım 4, 2 resimden 2.
      • Lift the top shell off carefully.
      FixBot'a Sor
      Yorum Ekle
    1. ionvac SmartClean V2 Motor Wheel Replacement, Motor Wheel: adım 5, 1 resimden 1.
      • Remove the 3 screws securing the cable assembly housing on the outer side of the motor wheel frame labeled either R (right wheel) or L (left wheel).
      • Set the cable assembly housing to the side.
      FixBot'a Sor
      Yorum Ekle
    2. ionvac SmartClean V2 Motor Wheel Replacement: adım 6, 2 resimden 1. ionvac SmartClean V2 Motor Wheel Replacement: adım 6, 2 resimden 2.
      • Unscrew the 3 screws securing the motor wheel frame.
      • Dislodge the wheel motor frame from the bottom shelf.
      FixBot'a Sor
      Yorum Ekle
    3. ionvac SmartClean V2 Motor Wheel Replacement: adım 7, 1 resimden 1.
      • Disconnect the cable attaching the motor wheel frame to the logic board.
      FixBot'a Sor
      Yorum Ekle
    4. ionvac SmartClean V2 Motor Wheel Replacement: adım 8, 2 resimden 1. ionvac SmartClean V2 Motor Wheel Replacement: adım 8, 2 resimden 2.
      • Carefully pull one end of the spring out of place to remove it from the motor wheel frame.
      • This will separate the motor wheel frame from the motor wheel assembly.
      FixBot'a Sor
      Yorum Ekle
    5. ionvac SmartClean V2 Motor Wheel Replacement: adım 9, 1 resimden 1.
      • Unscrew the five screws from the motor wheel assembly.
      FixBot'a Sor
      Yorum Ekle
    6. ionvac SmartClean V2 Motor Wheel Replacement: adım 10, 2 resimden 1. ionvac SmartClean V2 Motor Wheel Replacement: adım 10, 2 resimden 2.
      • Gently lift the clip on the side to separate the casing and expose the white plastic gears.
      FixBot'a Sor
      Yorum Ekle
    7. ionvac SmartClean V2 Motor Wheel Replacement: adım 11, 1 resimden 1.
      • Remove all but the largest gear to expose the silver screws and washers underneath.
      • Unscrew and remove the two silver screws along with each accompanying set of two washers.
      • Now you can remove the motor from the wheel assembly.
      • To clean the motor, use a soft cloth or alcohol wipe.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Andre
175 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 32
Her zaman: 1,051
