Ana içeriğe geç
jp.ik Leap T304 Battery Replacement Replacement
Neye ihtiyacın var
  1. jp.ik Leap T304 Battery Replacement Replacement, Rear Cover: adım 1, 1 resimden 1.
    • First ensure your laptop is turned off and check if you have the necessary tools
  2. jp.ik Leap T304 Battery Replacement Replacement: adım 2, 2 resimden 1. jp.ik Leap T304 Battery Replacement Replacement: adım 2, 2 resimden 2.
    • All screws are identified by circles. Pay special attention to the yellow circles, as the rubber feet hide screws.
  3. jp.ik Leap T304 Battery Replacement Replacement: adım 3, 3 resimden 1. jp.ik Leap T304 Battery Replacement Replacement: adım 3, 3 resimden 2. jp.ik Leap T304 Battery Replacement Replacement: adım 3, 3 resimden 3.
    • With the opening tool, remove a rubber foot.
    • For this action you will have to exert some force, because the foot is glued with a resistant glue.
  4. jp.ik Leap T304 Battery Replacement Replacement: adım 4, 1 resimden 1.
    • Remove all screws with a Philips screwdriver PH1
    • All screws are the same so don't worry about identifying them.
  5. jp.ik Leap T304 Battery Replacement Replacement: adım 5, 3 resimden 1. jp.ik Leap T304 Battery Replacement Replacement: adım 5, 3 resimden 2. jp.ik Leap T304 Battery Replacement Replacement: adım 5, 3 resimden 3.
    • With the plastic tool, insert between the plastics and gently pry open.
    • With your fingers continue to force open the bottom cover on the side indicated in the figure.
    • You will feel and hear several clicks, perfectly normal, nothing is breaking. Remove the cover completely.
  6. jp.ik Leap T304 Battery Replacement Replacement: adım 6, 1 resimden 1.
    • Finally, we have the laptop open and ready to replace most of its components. Look elsewhere on how to replace a component.
    • To close the laptop just follow this guide in reverse.
  7. jp.ik Leap T304 Battery Replacement Replacement, Battery Replacement or Removal: adım 7, 1 resimden 1.
    • Be careful to don't touch if not necessary any electrical part of the product and insure you're properly grounding.
  8. jp.ik Leap T304 Battery Replacement Replacement: adım 8, 1 resimden 1.
    • Remove mylers shown in the picture.
    • Save them for battery assembly steps
  9. jp.ik Leap T304 Battery Replacement Replacement: adım 9, 2 resimden 1. jp.ik Leap T304 Battery Replacement Replacement: adım 9, 2 resimden 2.
    • Disconnect the cable marked in the figure gently, pulling it out of the connector.
  10. jp.ik Leap T304 Battery Replacement Replacement: adım 10, 2 resimden 1. jp.ik Leap T304 Battery Replacement Replacement: adım 10, 2 resimden 2.
    • Gently remove the battery.
    • CAUTION!!
    • Some products may have this battery fixed with double-sided adhesive tape. In these cases, use a wide spatula to remove the battery without bending it.
    • SAFETY WARNING!
    • Never bend or puncture the battery. Danger of explosion. If you detect a swollen or damaged battery, handle it with extreme care and place it in a protective container.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nelson Oliveira
741 İtibar
4 adet Kılavuz yazıldı
Ekip
jp.ik jp.ik üyesi
Business
2 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 20
Her zaman: 289
