Ana içeriğe geç
nikon s3700 LCD Display Screen Replacement
Neye ihtiyacın var
  1. nikon s3700 LCD Display Screen Replacement, Removing the Screws: adım 1, 3 resimden 1. nikon s3700 LCD Display Screen Replacement, Removing the Screws: adım 1, 3 resimden 2. nikon s3700 LCD Display Screen Replacement, Removing the Screws: adım 1, 3 resimden 3.
    • group screws according to color code.
    • Remove exterior screws
  2. nikon s3700 LCD Display Screen Replacement, Replace LCD: adım 2, 3 resimden 1. nikon s3700 LCD Display Screen Replacement, Replace LCD: adım 2, 3 resimden 2. nikon s3700 LCD Display Screen Replacement, Replace LCD: adım 2, 3 resimden 3.
    • Remove Rear casing.
    • With a thin blade, gently lift the top tight hand side of the buttons board releasing a peg from a hole on the midframe below. Whilst doing so, gently push on the top left hand side in order to release the buttons board from a clip. At the same time, the bottom left hand corner wil be released from another clip.
    • Flip over rear buttons board to expose LCD ZIF clamp.
    • Flip open the clamp of the ZIF connector and slide the ribbon cable out. (The connector may have a piece of sticky tape over it. Removing this may well open the connector clamping bar.)
    • The ZIF clamp is very fragile so please use caution when releasing the ZIF clamp. It breaks easily.
    • Remove the LCD.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Sales Cameraparts4you
3.150 İtibar
20 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 355
