Ana içeriğe geç
removing the HP Elitebook 6930p Optical Drive
Neye ihtiyacın var
  1. removing the HP Elitebook 6930p Optical Drive, Battery Removal: adım 1, 3 resimden 1. removing the HP Elitebook 6930p Optical Drive, Battery Removal: adım 1, 3 resimden 2. removing the HP Elitebook 6930p Optical Drive, Battery Removal: adım 1, 3 resimden 3.
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. removing the HP Elitebook 6930p Optical Drive, Optical Drive: adım 2, 3 resimden 1. removing the HP Elitebook 6930p Optical Drive, Optical Drive: adım 2, 3 resimden 2. removing the HP Elitebook 6930p Optical Drive, Optical Drive: adım 2, 3 resimden 3.
    • With the bottom of the laptop facing up and the front toward you locate and loosen the M2.5×9.0 captive screw holding the optical drive into the laptop.
    • Insert a flat-bladed screwdriver or similar tool into the optical drive tab access hole and press the tab to the left to release the optical drive from the computer
    • The optical drive will unlock and pop out of the side of the laptop. You are now able to temove the optical drive from the laptop.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Richdave
32.413 İtibar
30 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
327 Üyeler
1.673 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 4
Her zaman: 4,197
