Ana içeriğe geç
ring Indoor Cam Body Replacement
Neye ihtiyacın var
  1. ring Indoor Cam Body Replacement, Body: adım 1, 3 resimden 1. ring Indoor Cam Body Replacement, Body: adım 1, 3 resimden 2. ring Indoor Cam Body Replacement, Body: adım 1, 3 resimden 3.
    • Place the cam with the base facing towards you.
    • Loosen the 21.6 mm silver screw using a Phillips #1 screwdriver.
    • Remove the base from the rest of the camera.
  2. ring Indoor Cam Body Replacement: adım 2, 2 resimden 1. ring Indoor Cam Body Replacement: adım 2, 2 resimden 2.
    • Place the cam with the top facing toward you.
    • Insert the iFixit opening pick into the crease at the top of the camera.
    • Slide the pick along the crease until you can separate the top cover of the camera from the backing.
    • Leave the pick in the crease.
  3. ring Indoor Cam Body Replacement: adım 3, 2 resimden 1. ring Indoor Cam Body Replacement: adım 3, 2 resimden 2.
    • Place the camera on its side where the horizontal crease is facing you.
    • Insert another iFixit opening pick into the crease between the front and back portions of the camera.
  4. ring Indoor Cam Body Replacement: adım 4, 3 resimden 1. ring Indoor Cam Body Replacement: adım 4, 3 resimden 2. ring Indoor Cam Body Replacement: adım 4, 3 resimden 3.
    • Slide the pick along the vertical crease until you can remove the back cover of the cam, using the opening tool to pry the portions apart.
    • You may hear a popping noise when you pry it open.
Sonuç
John Bray
411 İtibar
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 19
Son 30 gün: 86
Her zaman: 746
