Ana içeriğe geç
Giriş
it`s easy and very quick replacement. it could be completed even with fingerskate screwdriver, but i used simple philips 1,7 from my toolkit.
Parçalar
Hiçbir parça belirtilmedi.
  1. samsung sgh x820 samsung sgh x820 samsung sgh x820
    • samsung sgh x820
  2. after removing the battery, remove the five small Phillips-head screws with a #0 Phillips screwdriver. after removing the battery, remove the five small Phillips-head screws with a #0 Phillips screwdriver. after removing the battery, remove the five small Phillips-head screws with a #0 Phillips screwdriver.
    • after removing the battery, remove the five small Phillips-head screws with a #0 Phillips screwdriver.
  3. MacBook Pil Tamir Setleri
    Başlangıç $69.99
    Buy Now
    Başlangıç $69.99
    Buy Now
  4. now we have two more screws hiden first time i used needle. this time i took a blade. removing the last two philipps-head screws.
    • now we have two more screws hiden
    • first time i used needle. this time i took a blade.
    • removing the last two philipps-head screws.
  5. be carefull. the phone is thin and you should push on two hooks two open cover case.
    • be carefull. the phone is thin and you should push on two hooks two open cover case.
  6. now you should take of the square metal  in the middle of your phone to eject display.
    • now you should take of the square metal in the middle of your phone to eject display.
    • i used plastic spudger
  7. the last step is to take of old lcd from main board. mine was easy to go, but probably it could be stuck with the glue and i recommend to use a blade carefully.
    • the last step is to take of old lcd from main board. mine was easy to go, but probably it could be stuck with the glue and i recommend to use a blade carefully.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
sergeygraf
161 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 2
Son 30 Gün: 8
Her zaman: 1,173
