Giriş
This guide shows how to remove and replace an inner tube of a tire. This process may difficult he first time it is attempted.
Neye ihtiyacın var
Remove the flat tire by loosening and removing the axle nut with a 19 mm wrench.
Unscrew the axle bolt with a 19 mm socket wrench.
Remove the axle bolt from hole and remove the wheel from the wheelchair.
Bir başkası bu kılavuzu tamamladı.
