Ana içeriğe geç
the Nokia 6230b Camera Replacement
Neye ihtiyacın var
    1. the Nokia 6230b Camera Replacement, Back Cover: adım 1, 1 resimden 1.
      • Press down the button on the back panel.
      FixBot'a Sor
      Yorum Ekle
    2. the Nokia 6230b Camera Replacement: adım 2, 2 resimden 1. the Nokia 6230b Camera Replacement: adım 2, 2 resimden 2.
      • Push the back cover upwards.
      FixBot'a Sor
      Yorum Ekle
    3. the Nokia 6230b Camera Replacement: adım 3, 2 resimden 1. the Nokia 6230b Camera Replacement: adım 3, 2 resimden 2.
      • Remove the back cover from the phone.
      FixBot'a Sor
      Yorum Ekle
    1. the Nokia 6230b Camera Replacement, Front Cover: adım 4, 1 resimden 1.
      • Press the silver button on the top of the phone.
      FixBot'a Sor
      Yorum Ekle
    2. the Nokia 6230b Camera Replacement: adım 5, 1 resimden 1.
      • Slide your thumbnail down the case seam to separate the rest of the case.
      FixBot'a Sor
      Yorum Ekle
    3. the Nokia 6230b Camera Replacement: adım 6, 1 resimden 1.
      • Gently remove the case.
      • Careful! Do not bend the plastic tabs.
      FixBot'a Sor
      Yorum Ekle
    1. the Nokia 6230b Camera Replacement, Motherboard: adım 7, 2 resimden 1. the Nokia 6230b Camera Replacement, Motherboard: adım 7, 2 resimden 2.
      • Using a T6 Torx Screwdriver, unscrew and remove the six screws shown in the picture.
      FixBot'a Sor
      Yorum Ekle
    2. the Nokia 6230b Camera Replacement: adım 8, 2 resimden 1. the Nokia 6230b Camera Replacement: adım 8, 2 resimden 2.
      • Remove the panel that covers the motherboard.
      • If replacing the speaker, stop at this step and skip forward to the first step of the speaker guide.
      FixBot'a Sor
      Yorum Ekle
    3. the Nokia 6230b Camera Replacement: adım 9, 1 resimden 1.
      • Remove the LCD screen frame.
      FixBot'a Sor
      Yorum Ekle
    4. the Nokia 6230b Camera Replacement: adım 10, 1 resimden 1.
      • Remove the motherboard.
      FixBot'a Sor
      Yorum Ekle
    1. the Nokia 6230b Camera Replacement, Camera: adım 11, 1 resimden 1.
      • Locate the camera on the circuit board.
      FixBot'a Sor
      Yorum Ekle
    2. the Nokia 6230b Camera Replacement: adım 12, 1 resimden 1.
      • Place the circuit board on a firm, static free surface (no cloth/carpet).
      • NOTE: The circled alignment notch points to the left.
      FixBot'a Sor
      Yorum Ekle
    3. the Nokia 6230b Camera Replacement: adım 13, 1 resimden 1.
      • Pull the left holding tabs to the left.
      FixBot'a Sor
      Yorum Ekle
    4. the Nokia 6230b Camera Replacement: adım 14, 1 resimden 1.
      • Lift out the left side of the camera.
      FixBot'a Sor
      Yorum Ekle
    5. the Nokia 6230b Camera Replacement: adım 15, 1 resimden 1.
      • Pull the right holding tabs to the right.
      FixBot'a Sor
      Yorum Ekle
    6. the Nokia 6230b Camera Replacement: adım 16, 1 resimden 1.
      • Pull camera off of board.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Job Jao
37 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-27, Regan Fall 2010 Cal Poly, Team 3-27, Regan Fall 2010 üyesi
CPSU-REGAN-F10S3G27
4 Üyeler
105 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 43
Her zaman: 2,341
