Ana içeriğe geç
the Nokia 6230b Speaker Replacement
Neye ihtiyacın var
  1. the Nokia 6230b Speaker Replacement, Back Cover: adım 1, 1 resimden 1.
    • Press down the button on the back panel.
  2. the Nokia 6230b Speaker Replacement: adım 2, 2 resimden 1. the Nokia 6230b Speaker Replacement: adım 2, 2 resimden 2.
    • Push the back cover upwards.
  3. the Nokia 6230b Speaker Replacement: adım 3, 2 resimden 1. the Nokia 6230b Speaker Replacement: adım 3, 2 resimden 2.
    • Remove the back cover from the phone.
  4. the Nokia 6230b Speaker Replacement, Front Cover: adım 4, 1 resimden 1.
    • Press the silver button on the top of the phone.
  5. the Nokia 6230b Speaker Replacement: adım 5, 1 resimden 1.
    • Slide your thumbnail down the case seam to separate the rest of the case.
  6. the Nokia 6230b Speaker Replacement: adım 6, 1 resimden 1.
    • Gently remove the case.
    • Careful! Do not bend the plastic tabs.
  7. the Nokia 6230b Speaker Replacement, Motherboard: adım 7, 2 resimden 1. the Nokia 6230b Speaker Replacement, Motherboard: adım 7, 2 resimden 2.
    • Using a T6 Torx Screwdriver, unscrew and remove the six screws shown in the picture.
  8. the Nokia 6230b Speaker Replacement: adım 8, 2 resimden 1. the Nokia 6230b Speaker Replacement: adım 8, 2 resimden 2.
    • Remove the panel that covers the motherboard.
    • If replacing the speaker, stop at this step and skip forward to the first step of the speaker guide.
  9. the Nokia 6230b Speaker Replacement: adım 9, 1 resimden 1.
    • Remove the LCD screen frame.
  10. the Nokia 6230b Speaker Replacement: adım 10, 1 resimden 1.
    • Remove the motherboard.
  11. the Nokia 6230b Speaker Replacement, Speaker: adım 11, 1 resimden 1.
    • Locate the speaker on the back of the removed panel.
  12. the Nokia 6230b Speaker Replacement: adım 12, 1 resimden 1.
    • Use nails to gently lift the speaker up; speaker may be slightly glued to the panel.
  13. the Nokia 6230b Speaker Replacement: adım 13, 1 resimden 1.
    • When the speaker is loose, gently lift the speaker out of the panel.
Sonuç
Job Jao
37 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-27, Regan Fall 2010 Cal Poly, Team 3-27, Regan Fall 2010 üyesi
CPSU-REGAN-F10S3G27
4 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 2,772
