Ana içeriğe geç
Uyarı: Ön koşul olan bir kılavuzu düzenliyorsunuz. Yapacağınız herhangi bir değişiklik bu adımın yer aldığı bütün 80 kılavuzları etkileyecektir.
İngilizce
Fransızca
Adım 18 çevriliyor
Adım 18
With both plastic cards inserted as shown near the corners, gently twist the cards sideways to increase the gap between display and case. If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the remaining adhesive. Begin to lift the top of the display up from the frame.
  • With both plastic cards inserted as shown near the corners, gently twist the cards sideways to increase the gap between display and case.
  • If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the remaining adhesive.
  • Begin to lift the top of the display up from the frame.
  • Only lift the display a few inches—the display data and power cables are still connected to the logic board.
Les deux cartes étant insérées près des angles de l'iMac, comme illustré, tournez-les doucement pour élargir l'interstice entre l'écran et le boîtier.
Si l'écran et le boîtier restent collés à certains endroits, utilisez l'une des cartes pour découper la mousse adhésive et les séparer.
Commencez à soulever le haut de l'écran pour le séparer du cadre.
Soulevez l'écran de quelques centimètres seulement, car il est encore relié à la carte mère par les câbles de données et d'alimentation.
Katkılarınız, açık kaynak Creative Commons lisansı altında lisanslanmaktadır.
