Ana içeriğe geç
Uyarı: Ön koşul olan bir kılavuzu düzenliyorsunuz. Yapacağınız bütün değişiklikler bu adımın yer aldığı diğer kılavuzları da etkileyecektir.
İngilizce
Fransızca
Adım 1 çevriliyor
Adım 1
Examine your replacement part, and your original display carefully to be sure they match. Your replacement screen may be missing the sleep/wake sensor that is necessary for Smart Cover use. If you want to maintain functionality you will need to transfer the component. Desolder the four solder pads from the lower left of the display to remove the sensor assembly cable.
  • Examine your replacement part, and your original display carefully to be sure they match.
  • Your replacement screen may be missing the sleep/wake sensor that is necessary for Smart Cover use. If you want to maintain functionality you will need to transfer the component.
  • Desolder the four solder pads from the lower left of the display to remove the sensor assembly cable.
  • The following step includes instructions for transferring this sensor to the new display assembly.
Examinez votre pièce de rechange et votre écran d'origine pour vous assurer qu'ils correspondent.
Votre écran de remplacement peut manquer le capteur de marche/veille, qui est nécessaire pour l'utilisation de Smart Cover. Si vous souhaitez garder cette fonction, vous devrez transférer le composant.
Dessoudez les quatre plaques de soudure en bas à gauche de l'écran pour enlever la nappe de l'ensemble capteur.
L'étape suivante inclut des instructions pour transférer ce capteur vers le nouvel écran.
Katkılarınız, açık kaynak Creative Commons lisansı altında lisanslanmaktadır.
