Ana içeriğe geç
Apple AirPort Express Base Station Power Supply Kit
Adım 34 çevriliyor
İngilizce
Fransızca
Adım 34
Apple AirPort Express Base Station Power Supply Kit: adım 0, 2 resimden 1. Apple AirPort Express Base Station Power Supply Kit: adım 0, 2 resimden 2.
  • Give the plastic beads a few seconds to cool, then remove them and mash them together until they form one piece.
  • The plastic beads should be fairly warm still, but their container will likely be extremely hot. Use care when removing and handling the beads.
  • Stretch the glob of plastic into a thin strip that will fill one of the gaps between the case halves.
  • Press the plastic into the crevices and smooth it out with your finger.
  • If the plastic becomes too hard to work with, you can re-apply heat to loosen the plastic.
  • Be cautious if you reheat the plastic while it's in the case. Allow cooling periods between reheating so you don't accidentally de-solder any components.
Çeviri buraya girin
Çeviri buraya girin
Çeviri buraya girin
Çeviri buraya girin
Çeviri buraya girin
Çeviri buraya girin
Katkılarınız, açık kaynak Creative Commons lisansı altında lisanslanmaktadır.
