Ana içeriğe geç
uAttend bn6000 Fingerprint Replacement
Neye ihtiyacın var
  1. uAttend bn6000 Fingerprint Replacement, Disassembly: adım 1, 1 resimden 1.
    • Make sure to unplug the device before starting.
    • Flip the device over.
    • Remove the four 10mm PH #2 screws by rotating the screwdriver counterclockwise, removing the screw from the housing completely.
    FixBot'a Sor
    Yorum Ekle
  2. uAttend bn6000 Fingerprint Replacement: adım 2, 1 resimden 1.
    • Separate the two cover pieces carefully by pulling apart the two cover pieces away from each other.
    FixBot'a Sor
    Yorum Ekle
  3. uAttend bn6000 Fingerprint Replacement, Fingerprint: adım 3, 3 resimden 1. uAttend bn6000 Fingerprint Replacement, Fingerprint: adım 3, 3 resimden 2. uAttend bn6000 Fingerprint Replacement, Fingerprint: adım 3, 3 resimden 3.
    • Remove the two 7mm PH #1 screws from the fingerprint scanner mounting tab by rotating the screw driver counter clockwise, removing the screw from the housing completely.
    • Remove the fingerprint scanner assembly from the unit by lifting the scanner up and away from the unit housing.
    FixBot'a Sor
    Yorum Ekle
  4. uAttend bn6000 Fingerprint Replacement: adım 4, 3 resimden 1. uAttend bn6000 Fingerprint Replacement: adım 4, 3 resimden 2. uAttend bn6000 Fingerprint Replacement: adım 4, 3 resimden 3.
    • Disconnect the ZIF connector, by using your fingernail to lift up on the small locking flap. Then pull the ribbon up and away, out of the connector.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble , follow these instructions in reverse order.
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 15
Son 30 gün: 41
Her zaman: 920
