Ana içeriğe geç
why! N131WU Screen Replacement
Neye ihtiyacın var
  1. why! N131WU Screen Replacement, Remove the Screws: adım 1, 1 resimden 1.
    • Remove the case screws (red) and the keyboard screws (green).
    • Be sure not to lose these screws. You will need them to reassemble your laptop.
  2. why! N131WU Screen Replacement, Remove the Keyboard: adım 2, 3 resimden 1. why! N131WU Screen Replacement, Remove the Keyboard: adım 2, 3 resimden 2. why! N131WU Screen Replacement, Remove the Keyboard: adım 2, 3 resimden 3.
    • Using the hole provided under the case (see picture), push the keyboard out using a thin screwdriver or some other solid object.
    • Hold onto the keyboard as you push the keyboard so as not to damage the two cables still attached.
  3. why! N131WU Screen Replacement, Remove Keyboard Connections: adım 3, 3 resimden 1. why! N131WU Screen Replacement, Remove Keyboard Connections: adım 3, 3 resimden 2. why! N131WU Screen Replacement, Remove Keyboard Connections: adım 3, 3 resimden 3.
    • (Blue Cable) Push up on the thin black portion on the connector and gently pull out the blue ribbon cable until it comes out.
    • (Orange Cable) Remove the orange cable by sliding the gray part of the connector towards the screen, then gently pull on the ribbon cable.
  4. why! N131WU Screen Replacement, Remove the upper screws: adım 4, 2 resimden 1. why! N131WU Screen Replacement, Remove the upper screws: adım 4, 2 resimden 2.
    • Unscrew the three screws that were under the keyboard. Be sure to hold onto these.
    • After these are removed, you can now remove the lower part of the case from the rest of the computer.
  5. why! N131WU Screen Replacement, Remove the SSD: adım 5, 3 resimden 1. why! N131WU Screen Replacement, Remove the SSD: adım 5, 3 resimden 2. why! N131WU Screen Replacement, Remove the SSD: adım 5, 3 resimden 3.
    • Remove the screw holding in the ssd.
    • Carefully remove the SSD from the connector.
  6. why! N131WU Screen Replacement, RAM (Memory): adım 6, 3 resimden 1. why! N131WU Screen Replacement, RAM (Memory): adım 6, 3 resimden 2. why! N131WU Screen Replacement, RAM (Memory): adım 6, 3 resimden 3.
    • Gently pull outwards on the clips to free the RAM stick.
    • Remove the RAM Stick from its slot.
  7. why! N131WU Screen Replacement, Battery: adım 7, 2 resimden 1. why! N131WU Screen Replacement, Battery: adım 7, 2 resimden 2.
    • Remove the five Phillips screws securing the battery.
    • Unplug the power connector and lift the battery out in the direction of the arrows to remove it.
  8. why! N131WU Screen Replacement, Motherboard: adım 8, 3 resimden 1. why! N131WU Screen Replacement, Motherboard: adım 8, 3 resimden 2. why! N131WU Screen Replacement, Motherboard: adım 8, 3 resimden 3.
    • Lift the retaining latch and unplug the ZIF cable found under the keyboard.
    • Disconnect the nine marked cables as detailed in the following steps.
    • Remove the four screws securing the motherboard to the case.
  9. why! N131WU Screen Replacement, ZIF Connectors: adım 9, 3 resimden 1. why! N131WU Screen Replacement, ZIF Connectors: adım 9, 3 resimden 2. why! N131WU Screen Replacement, ZIF Connectors: adım 9, 3 resimden 3.
    • The cables with the blue reinforcing tabs are ZIF connectors that require you to lift the retaining lever before removing the cable.
  10. why! N131WU Screen Replacement, SATA Cable: adım 10, 3 resimden 1. why! N131WU Screen Replacement, SATA Cable: adım 10, 3 resimden 2. why! N131WU Screen Replacement, SATA Cable: adım 10, 3 resimden 3.
    • Remove the SATA3 cable from the motherboard after disconnecting it.
  11. why! N131WU Screen Replacement, Motherboard (continued): adım 11, 2 resimden 1. why! N131WU Screen Replacement, Motherboard (continued): adım 11, 2 resimden 2.
    • Don't forget to remove these cables.
  12. why! N131WU Screen Replacement, Display Connector: adım 12, 2 resimden 1. why! N131WU Screen Replacement, Display Connector: adım 12, 2 resimden 2.
    • Note: The original instructions call for inserting your thumbnail firmly under the base of the display connector
    • However, the proper way to remove the display connector is to grasp the plastic strap on top of the connector and use it to pull the connector straight up.
  13. why! N131WU Screen Replacement, Remove the Motherboard: adım 13, 3 resimden 1. why! N131WU Screen Replacement, Remove the Motherboard: adım 13, 3 resimden 2. why! N131WU Screen Replacement, Remove the Motherboard: adım 13, 3 resimden 3.
    • Once the screws have been removed, carefully lift the motherboard from the end indicated by the arrows.
    • Remember to disconnect the cables near the fan.
  14. why! N131WU Screen Replacement, Motherboard (continued): adım 14, 1 resimden 1.
    • The motherboard has been successfully removed.
  15. why! N131WU Screen Replacement, Screen: adım 15, 3 resimden 1. why! N131WU Screen Replacement, Screen: adım 15, 3 resimden 2. why! N131WU Screen Replacement, Screen: adım 15, 3 resimden 3.
    • Unclip the display bezel from the frame starting at the top.
    • To remove the lower part, open the display as far as possible.
    • Warning, the frame of the screen may be glued at the bottom. When pulling as shown, there is a big risk of damaging the screen. You may want to use a plastic tab to separate it gradually.
  16. why! N131WU Screen Replacement: adım 16, 2 resimden 1. why! N131WU Screen Replacement: adım 16, 2 resimden 2.
    • The LCD is secured with adhesive. Use an opening pick to separate the LCD from the display lid.
    • Carefully lay the LCD down on the keyboard.
    • Unplug the display connector at the bottom of the screen.
Sonuç
Bu çevirmenlere özel teşekkürler:
fr en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Felice Suglia
33.538 İtibar
283 adet Kılavuz yazıldı
5Kılavuz Yorumları
bonjour, pourriez-vous rajouter la manière dont on débranche le cable EDP entre carte mère et écran,
je n'ose pas tirer et je ne sais dans quelle direction! merci!
Didier Chakchouka - Yanıt
Step 14 of the why! N131WU Motherboard Replacement guide shows how to unplug the other end of the display cable from the motherboard. You will need to follow the first four steps of that guide in order to gain access to it.
Jerry Wheeler -
merci! je vais regarder cela!
Bonjour ,
Il n'est pas nécessaire de retirer la carte mère , seules les étapes 15 et 16 sont nécessaire pour changer l'écran
EkimiaMichel - Yanıt
En effet, il n'est pas nécessaire de retirer la carte mère, mais il faut tout de même suivre l'étape 12 si on veut changer le câble EDP. Il n'est pas exclu que nous devrions mettre à jour certains de nos tutos.
Felice Suglia -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 584
