Ana içeriğe geç
why! N240JU Replacing the LCD screen
Neye ihtiyacın var
  1. why! N240JU Replacing the LCD screen, Battery: adım 1, 2 resimden 1. why! N240JU Replacing the LCD screen, Battery: adım 1, 2 resimden 2.
    • Start by unlocking the right locking latch.
    • Then, by simultaneously unlocking the left latch, lift the battery out of its socket.
  2. why! N240JU Replacing the LCD screen, Access to main components: adım 2, 2 resimden 1. why! N240JU Replacing the LCD screen, Access to main components: adım 2, 2 resimden 2.
    • Begin by spotting the dummy memory card.
    • Then, remove it and put it on your workplan.
  3. why! N240JU Replacing the LCD screen: adım 3, 3 resimden 1. why! N240JU Replacing the LCD screen: adım 3, 3 resimden 2. why! N240JU Replacing the LCD screen: adım 3, 3 resimden 3.
    • Locate the 15 screws that hold the bottom cover of the device in place.
    • Unscrew them and place them on your work surface.
    • Then, un-clip the bottom cover, starting with the side shown in the third picture.
  4. why! N240JU Replacing the LCD screen, LCD screen: adım 4, 3 resimden 1. why! N240JU Replacing the LCD screen, LCD screen: adım 4, 3 resimden 2. why! N240JU Replacing the LCD screen, LCD screen: adım 4, 3 resimden 3.
    • In order to remove the LCD screen, you must remove the connection cables from the Wi-Fi chipset.
    • Then locate the two connectors on the LCD screen.
    • Disconnect the first connector.
  5. why! N240JU Replacing the LCD screen: adım 5, 3 resimden 1. why! N240JU Replacing the LCD screen: adım 5, 3 resimden 2. why! N240JU Replacing the LCD screen: adım 5, 3 resimden 3.
    • Peel off the tape from the second connector.
    • Then disconnect the second connector.
    • Locate the SSD M.2 drive.
  6. why! N240JU Replacing the LCD screen: adım 6, 3 resimden 1. why! N240JU Replacing the LCD screen: adım 6, 3 resimden 2. why! N240JU Replacing the LCD screen: adım 6, 3 resimden 3.
    • Then dismount this disk because it must release the connection cables of the Wi-Fi chipset.
    • Free Wi-Fi connection cables now
    • Now locate the two screws that secure the screen to the rest of the Laptop (fan side)
  7. why! N240JU Replacing the LCD screen: adım 7, 3 resimden 1. why! N240JU Replacing the LCD screen: adım 7, 3 resimden 2. why! N240JU Replacing the LCD screen: adım 7, 3 resimden 3.
    • Now locate the two screws that secure the screen to the rest of the Laptop (the other side).
    • Then lift the Laptop as shown in the second image of this step.
    • Unscrew the first screw.
  8. why! N240JU Replacing the LCD screen: adım 8, 3 resimden 1. why! N240JU Replacing the LCD screen: adım 8, 3 resimden 2. why! N240JU Replacing the LCD screen: adım 8, 3 resimden 3.
    • Then unscrew the second screw.
    • Rest the Laptop as shown in the second image of this step and unscrew the third screw.
    • Then the fourth screw.
  9. why! N240JU Replacing the LCD screen: adım 9, 3 resimden 1. why! N240JU Replacing the LCD screen: adım 9, 3 resimden 2. why! N240JU Replacing the LCD screen: adım 9, 3 resimden 3.
    • With the four screws unscrewed, separate the screen from the rest of the Laptop. Note that the hinge remains attached to the screen.
    • On the screen near the hinge now locate the two caches screws on the left.
    • Then look for those on the right.
  10. why! N240JU Replacing the LCD screen: adım 10, 3 resimden 1. why! N240JU Replacing the LCD screen: adım 10, 3 resimden 2. why! N240JU Replacing the LCD screen: adım 10, 3 resimden 3.
    • Now remove the screw covers near the left hinge.
    • first on the right side of the hinge.
    • then on the left side.
  11. why! N240JU Replacing the LCD screen: adım 11, 3 resimden 1. why! N240JU Replacing the LCD screen: adım 11, 3 resimden 2. why! N240JU Replacing the LCD screen: adım 11, 3 resimden 3.
    • Repeat near the right hinge
    • .Now return to the hinge on the left side and unscrew the outer screw.
  12. why! N240JU Replacing the LCD screen: adım 12, 3 resimden 1. why! N240JU Replacing the LCD screen: adım 12, 3 resimden 2. why! N240JU Replacing the LCD screen: adım 12, 3 resimden 3.
    • Then unscrew the inner screw.
    • Repeat on the side of the right hinge.
  13. why! N240JU Replacing the LCD screen: adım 13, 3 resimden 1. why! N240JU Replacing the LCD screen: adım 13, 3 resimden 2. why! N240JU Replacing the LCD screen: adım 13, 3 resimden 3.
    • You can now gently unclip the screen cover.
    • Locate the left hinge screw cover.
    • Locate the right hinge screw cover.
  14. why! N240JU Replacing the LCD screen: adım 14, 3 resimden 1. why! N240JU Replacing the LCD screen: adım 14, 3 resimden 2. why! N240JU Replacing the LCD screen: adım 14, 3 resimden 3.
    • Gently remove the screw cover on the left hinge.
    • Also remove the screw cover on the right hinge.
    • Once the screw caps are removed you will see the fixing screws.
  15. why! N240JU Replacing the LCD screen: adım 15, 3 resimden 1. why! N240JU Replacing the LCD screen: adım 15, 3 resimden 2. why! N240JU Replacing the LCD screen: adım 15, 3 resimden 3.
    • Now unscrew the screw on the left hinge.
    • Then unscrew the screw on the right hinge.
    • Once this is done you can now remove the hinge cover (left).
  16. why! N240JU Replacing the LCD screen: adım 16, 3 resimden 1. why! N240JU Replacing the LCD screen: adım 16, 3 resimden 2. why! N240JU Replacing the LCD screen: adım 16, 3 resimden 3.
    • Left hinged cover removed.
    • Then remove the cover from the right hinge.
    • Right hinge cover removed.
  17. why! N240JU Replacing the LCD screen: adım 17, 3 resimden 1. why! N240JU Replacing the LCD screen: adım 17, 3 resimden 2. why! N240JU Replacing the LCD screen: adım 17, 3 resimden 3.
    • once these operations are done you see the LCD screen ready to be dismounted.
    • Now locate the screws that secure the LCD screen to the bracket and unscrew them. Two on the left.
    • Two on the right.
  18. why! N240JU Replacing the LCD screen: adım 18, 3 resimden 1. why! N240JU Replacing the LCD screen: adım 18, 3 resimden 2. why! N240JU Replacing the LCD screen: adım 18, 3 resimden 3.
    • Once the screws are unscrewed, lift the LCD screen gently and flip it over.
    • You will then see the connection cable of the screen.
    • Locate its connector.
  19. why! N240JU Replacing the LCD screen: adım 19, 2 resimden 1. why! N240JU Replacing the LCD screen: adım 19, 2 resimden 2.
    • Disconnect the cable.
    • And here you can now put it on your work plan.
Sonuç
To reassemble your device, Follow these instructions in reverse order.
Bir başkası bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
fr en
100%
irlanda dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Felice Suglia
33.538 İtibar
283 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 551
