Neye ihtiyacın var
Slide the latch on the right to the unlocked position.
Slide the latch on the left to the unlocked position.
Remove the battery pack from the slot.
With your #0 Philips screwdriver remove the 2 screws from the bottom panel.
Now you can remove the bottom cover.
Lift out the plastic tab (including the rubber part that holds the HDD in its slot).
Slide the drive to the left to disengage the connector then lift to remove the HDD from its SATA3 port.
Bu çevirmenlere özel teşekkürler:
100%
Jerry Wheeler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
