Ana içeriğe geç
why! W650SZ Keyboard Replacement
Neye ihtiyacın var
  1. why! W650SZ Keyboard Replacement, Battery: adım 1, 3 resimden 1. why! W650SZ Keyboard Replacement, Battery: adım 1, 3 resimden 2. why! W650SZ Keyboard Replacement, Battery: adım 1, 3 resimden 3.
    • Slide the latch on the right to the unlocked position.
    • Slide the latch on the left to the unlocked position.
    • Remove the battery pack from the slot.
  2. why! W650SZ Keyboard Replacement, why! W650SZ Bottom Cover Replacement: adım 2, 3 resimden 1. why! W650SZ Keyboard Replacement, why! W650SZ Bottom Cover Replacement: adım 2, 3 resimden 2. why! W650SZ Keyboard Replacement, why! W650SZ Bottom Cover Replacement: adım 2, 3 resimden 3.
    • With your #0 Philips screwdriver remove the 2 screws from the bottom panel.
    • Now you can remove the bottom cover.
  3. why! W650SZ Keyboard Replacement, Keyboard: adım 3, 3 resimden 1. why! W650SZ Keyboard Replacement, Keyboard: adım 3, 3 resimden 2. why! W650SZ Keyboard Replacement, Keyboard: adım 3, 3 resimden 3.
    • Press gently at the points indicated to release the LED cover strip.
    • Turn the laptop over, then lift the LED cover.
    • Remove the LED cover.
  4. why! W650SZ Keyboard Replacement: adım 4, 3 resimden 1. why! W650SZ Keyboard Replacement: adım 4, 3 resimden 2. why! W650SZ Keyboard Replacement: adım 4, 3 resimden 3.
    • The five screws that anchor the keyboard are now visible.
    • Start by removing the first screw.
    • Remove the remaining screws (2-5).
  5. why! W650SZ Keyboard Replacement: adım 5, 3 resimden 1. why! W650SZ Keyboard Replacement: adım 5, 3 resimden 2. why! W650SZ Keyboard Replacement: adım 5, 3 resimden 3.
    • Dismount the keyboard from the chassis.
    • Flip the keyboard forward, taking care as it is still connected by a cable to the motherboard.
    • Release the cable latch on the right side of the motherboard connector with a small flat blade screwdriver.
  6. why! W650SZ Keyboard Replacement: adım 6, 3 resimden 1. why! W650SZ Keyboard Replacement: adım 6, 3 resimden 2. why! W650SZ Keyboard Replacement: adım 6, 3 resimden 3.
    • Release the cable latch on the left side of the motherboard connector.
    • Slide the cable straight out from its connector.
    • Remove the keyboard.
Sonuç
Bu çevirmenlere özel teşekkürler:
fr en
100%
Jerry Wheeler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Felice Suglia
31.564 İtibar
264 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 13
Her zaman: 213
