Neye ihtiyacın var
Open the latch of the accumulator on the left side.
Open the battery latch on the right side.
Remove the accumulator by simultaneously holding the right-hand latch open.
Use the Philips screwdriver to remove the two screws at the bottom of the cover.
Lift the cover at the bottom right with the iFixit Opening Tool
Lift the cover at the bottom left with the iFixit Opening Tool
Finally, remove the cover to gain access to the most important components.
First, locate the fan. Then pull out the supply cable of the fan.
Remove the three retaining screws of the fan.
Finally, remove the fan by lifting it out.
Repeat the steps in reverse order to reassemble your device.
Bu çevirmenlere özel teşekkürler:
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
