Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
  1. Open the latch of the accumulator on the left side. Open the battery latch on the right side. Remove the accumulator by simultaneously holding the right-hand latch open.
    • Open the latch of the accumulator on the left side.
    • Open the battery latch on the right side.
    • Remove the accumulator by simultaneously holding the right-hand latch open.
  2. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  3. Use the Philips screwdriver to remove the two screws at the bottom of the cover. Lift the cover at the bottom right with the iFixit Opening Tool Lift the cover at the bottom left with the iFixit Opening Tool
    • Use the Philips screwdriver to remove the two screws at the bottom of the cover.
    • Lift the cover at the bottom right with the iFixit Opening Tool
    • Lift the cover at the bottom left with the iFixit Opening Tool
    • Finally, remove the cover to gain access to the most important components.
  4. Locate the HDD disk. Lift the plastic tab and pull the HDD hard drive out of its SATA connector.
    • Locate the HDD disk.
    • Lift the plastic tab and pull the HDD hard drive out of its SATA connector.
Sonuç
Repeat the steps in reverse order to reassemble your device.
Bu çevirmenlere özel teşekkürler:
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Felice Suglia
14.934 İtibar
150 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 86
