Ana içeriğe geç
why! W670SZQ1 Replacing the LCD screen
Neye ihtiyacın var
  1. why! W670SZQ1 Replacing the LCD screen, The Batteries: adım 1, 3 resimden 1. why! W670SZQ1 Replacing the LCD screen, The Batteries: adım 1, 3 resimden 2. why! W670SZQ1 Replacing the LCD screen, The Batteries: adım 1, 3 resimden 3.
    • Unlock the lock latch on the left.
    • Unlock the lock latch on the right.
    • Remove the battery while holding the lock latch unlocked.
  2. why! W670SZQ1 Replacing the LCD screen, LCD screen: adım 2, 3 resimden 1. why! W670SZQ1 Replacing the LCD screen, LCD screen: adım 2, 3 resimden 2. why! W670SZQ1 Replacing the LCD screen, LCD screen: adım 2, 3 resimden 3.
    • Start by locating the two screw caps on the left side of the screen.
    • Remove the lower screw cover.
    • Then the top screw cover.
  3. why! W670SZQ1 Replacing the LCD screen: adım 3, 3 resimden 1. why! W670SZQ1 Replacing the LCD screen: adım 3, 3 resimden 2. why! W670SZQ1 Replacing the LCD screen: adım 3, 3 resimden 3.
    • Locate and then remove the first center screw on the top of the screen frame.
    • Then the second central cap on the top of the screen frame.
    • Then locate and remove the screw cap on the upper right side of the screen frame.
  4. why! W670SZQ1 Replacing the LCD screen: adım 4, 3 resimden 1. why! W670SZQ1 Replacing the LCD screen: adım 4, 3 resimden 2. why! W670SZQ1 Replacing the LCD screen: adım 4, 3 resimden 3.
    • Then finally the bottom right screw cap of the screen frame.
    • Then unscrew the screws behind the screw caps, starting with the one at the bottom left of the frame.
    • Then at the top left.
  5. why! W670SZQ1 Replacing the LCD screen: adım 5, 3 resimden 1. why! W670SZQ1 Replacing the LCD screen: adım 5, 3 resimden 2. why! W670SZQ1 Replacing the LCD screen: adım 5, 3 resimden 3.
    • Then the first central screw on the top edge of the frame.
    • Then the second central screw on the top edge of the frame.
    • Then the one in the upper right corner of the frame.
  6. why! W670SZQ1 Replacing the LCD screen: adım 6, 3 resimden 1. why! W670SZQ1 Replacing the LCD screen: adım 6, 3 resimden 2. why! W670SZQ1 Replacing the LCD screen: adım 6, 3 resimden 3.
    • And finally the one on the lower right side of the frame.
    • Then gently use your nails.
    • To remove the frame from the LCD screen.
  7. why! W670SZQ1 Replacing the LCD screen: adım 7, 3 resimden 1. why! W670SZQ1 Replacing the LCD screen: adım 7, 3 resimden 2. why! W670SZQ1 Replacing the LCD screen: adım 7, 3 resimden 3.
    • Unscrew the screws on the front of the LCD screen.
    • Next, unscrew the screws on the right side of the LCD screen, starting with the first one.
    • Then the second.
  8. why! W670SZQ1 Replacing the LCD screen: adım 8, 3 resimden 1. why! W670SZQ1 Replacing the LCD screen: adım 8, 3 resimden 2. why! W670SZQ1 Replacing the LCD screen: adım 8, 3 resimden 3.
    • Then the third.
    • And finally the fourth.
    • Repeat these operations then on the left side of the screen starting with the first screw.
  9. why! W670SZQ1 Replacing the LCD screen: adım 9, 3 resimden 1. why! W670SZQ1 Replacing the LCD screen: adım 9, 3 resimden 2. why! W670SZQ1 Replacing the LCD screen: adım 9, 3 resimden 3.
    • Then the second.
    • Then the third. .
  10. why! W670SZQ1 Replacing the LCD screen: adım 10, 3 resimden 1. why! W670SZQ1 Replacing the LCD screen: adım 10, 3 resimden 2. why! W670SZQ1 Replacing the LCD screen: adım 10, 3 resimden 3.
    • Then flip the LCD screen.
    • Then appears the connector to which is attached the connection cable of the LCD.
    • Then peel off the tape covering the connector.
  11. why! W670SZQ1 Replacing the LCD screen: adım 11, 3 resimden 1. why! W670SZQ1 Replacing the LCD screen: adım 11, 3 resimden 2. why! W670SZQ1 Replacing the LCD screen: adım 11, 3 resimden 3.
    • then remove the cable from its connector.
    • Once the cable is disconnected you can release the LCD screen.
Sonuç
to reassemble your device follow these instructions in reverse order.
Bu çevirmenlere özel teşekkürler:
fr en
100%
irlanda dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Felice Suglia
33.538 İtibar
283 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 225
