Ana içeriğe geç
why! WDi7SSD fan replacement
Neye ihtiyacın var
  1. why! WDi7SSD fan replacement, why! WDi7SSD Opening procedure: adım 1, 3 resimden 1. why! WDi7SSD fan replacement, why! WDi7SSD Opening procedure: adım 1, 3 resimden 2. why! WDi7SSD fan replacement, why! WDi7SSD Opening procedure: adım 1, 3 resimden 3.
    • Make sure the computer is disconnected from the power source.
    • Flip the computer over.
    • Remove the six screws with a 2 mm Allen key.
    • Carefully remove the back panel, as well the left and right panel.
  2. why! WDi7SSD fan replacement: adım 2, 1 resimden 1.
    • Now flip up the base panel to which all components are attached.
  3. why! WDi7SSD fan replacement, Fan: adım 3, 2 resimden 1. why! WDi7SSD fan replacement, Fan: adım 3, 2 resimden 2.
    • Remove the two Phillips PH2 screws on the fan.
  4. why! WDi7SSD fan replacement: adım 4, 2 resimden 1. why! WDi7SSD fan replacement: adım 4, 2 resimden 2.
    • Remove the cable connecting the front part (with the LEDs) to the power source.
    • Remove that part of the case and its cable.
  5. why! WDi7SSD fan replacement: adım 5, 3 resimden 1. why! WDi7SSD fan replacement: adım 5, 3 resimden 2. why! WDi7SSD fan replacement: adım 5, 3 resimden 3.
    • Remove the four screws on the heat sink with a Phillips PH2 screwdriver.
    • Remove the heat sink.
  6. why! WDi7SSD fan replacement: adım 6, 2 resimden 1. why! WDi7SSD fan replacement: adım 6, 2 resimden 2.
    • Carefully remove the fan together with its case.
    • Carefully remove the connector connecting the fan to the power source.
Sonuç
In order to reassemble your device, follow the steps of this guide in reverse order.
Bu çevirmenlere özel teşekkürler:
de en
100%
Maria Parker dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Felice Suglia
33.538 İtibar
283 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 324
