4 TB 3.5" Hard Drive
  • 4 TB 3.5" Hard Drive
Model #: ST4000DM005
$159,99
$159,99
Ürün tekrar stoklarımızda mevcut olduğunda size bir mesaj göndereceğiz.
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
Ürün Detayı
Açıklama
Açıklama
Replace or upgrade the hard drive in your compatible iMac with this part.
Not
To ensure compatibility with the 2009 and 2010 21.5" or 27" iMac, the replacement hard drive must be of the same brand as the original. The model number of the hard drive does not matter as long as the brand matches. 2011 and up iMacs cannot be supported by us.
Not
Works only in iMac G5s and Intel iMacs (excluding 2011 and up 21.5" and 27" models).
Uyumluluk
iMac G5 17" Model A1058
1.8 GHz (EMC No. 2055)
2 GHz
iMac G5 17" Model A1144
1.9 GHz
iMac G5 20" Model A1076
1.8 GHz
2 GHz
iMac G5 20" Model A1145
2.1 GHz
iMac Intel 17"
1.83 GHz (EMC No. 2104)
1.83 GHz (EMC No. 2110)
1.83 GHz (EMC No. 2124)
2 GHz
2.16 GHz
iMac Intel 20" EMC 2105 and 2118
2 GHz
2.16 GHz
2.33 GHz
iMac Intel 20" EMC 2133 and 2210
2 GHz (EMC No. 2133)
2.4 GHz (EMC No. 2133)
2.4 GHz (EMC No. 2210)
2.66 GHz (EMC No. 2210)
iMac Intel 20" EMC 2266
2.66 GHz
iMac Intel 21.5" EMC 2308
EMC 2308 3.06 GHz
EMC 2308 3.33 GHz
iMac Intel 21.5" EMC 2389
EMC 2389 3.06 GHz
EMC 2389 3.2 GHz
EMC 2389 3.6 GHz
iMac Intel 24" EMC 2111
2.16 GHz
2.33 GHz
iMac Intel 24" EMC 2134 and 2211
2.4 GHz (EMC No. 2134)
2.8 GHz (EMC No. 2134)
2.8 GHz (EMC No. 2211)
3.06 GHz (EMC No. 2211)
iMac Intel 24" EMC 2267
2.66 GHz
2.93 GHz
3.06 GHz
iMac Intel 27" EMC 2309 and 2374
2.66 GHz (Late 2009)
2.8 GHz (Late 2009)
3.06 GHz (Late 2009)
3.33 GHz (Late 2009)
iMac Intel 27" EMC 2390
2.8 GHz (Mid 2010)
2.93 GHz (Mid 2010)
3.2 GHz (Mid 2010)
3.6 GHz (Mid 2010)
Power Mac G5
1.6 GHz
1.8 GHz (EMC No. 1969)
1.8 GHz (Late 2004)
1.8 GHz Dual (EMC No. 1969)
1.8 GHz Dual (EMC No. 1969C)
2.0 GHz Dual (EMC No. 1969)
2.0 GHz Dual (EMC No. 1969C)
2.0 GHz Dual (EMC No. 2023)
2.0 GHz Dual (EMC No. 2061)
2.3 GHz Dual (EMC No. 2023)
2.3 GHz Dual (EMC No. 2061)
2.5 GHz Dual (EMC No. 1969C)
2.5 GHz Quad
2.7 GHz Dual
13 cihaz daha göster
Onarım hikayeleri
Kullanıcı avatarı
emholden's Story Photo #1169046
emholden's Story Photo #1169050
emholden's Story Photo #1169049
Sorunum
My iMac is 7 years old and was getting slow and glitchy
Tamirim
I asked an ifixit staff to guide me to the right hardware because you can't just throw any old HD in a mac. For barely more than $200 I went from a slow 1TB 8g computer to a perfect 4TB 12g computer!!! It was pretty seamless! Everything you ne . . .
Kullanıcı avatarı
Joseph Abraham's Story Photo #340212
Sorunum
Original hard drive went bad, had to replace it.
Tamirim
Repair went smooth. However, I did forget to attach one cable prior to reassembly. I had to open the unit back up and reattach the video cable. I ended up actually shocking myself because when I reopened the computer, I forgot to unplug the computer.
Kullanıcı avatarı
Sorunum
Hard Drive was showing problems and was concerned that it could fail at any time, so opted to replace it with a bigger capacity drive.
Tamirim
I knew from the iFixit advice that the drive had to be replaced by a similar brand to the existing HD which turned out to be Seagate, so it took a week before I had t . . .
Kullanıcı avatarı
Sorunum
I knew the hard drive on my 27" iMac was beginning to fail. It was getting slower, programs took longer to load, it was just a matter of time before it went belly up and died. Decided to be pro active and research what to do and if I could handle the repair myself.
Tamirim
The repair went well- looked over t . . .
Kullanıcı avatarı
Sorunum
We were running out of disk space with our 500 GB disk on our late-2009 iMac, and I was fed up managing content on external USB drives.
Tamirim
It was actually quite easy. It only took about 45 minutes and my 12 year old daughter did most of the work. The guide for the EMC 2308 was spot on for my iMac, whi . . .
Kullanıcı avatarı
Sorunum
Wanted larger local data internal repository with rapid loading apps/programs. Fed up of slow wifi and ethernet network filesystem update and waiting ages for file updates and backups. Went for Fusion drive using SSD and 4TB Seagate HDD
Tamirim
Nothing exploded!. Went back together perfectly. Need plenty of . . .
Daha fazla göster
Bu ürünü satın alan müşteriler aynı zamanda aşağıdaki ürünleri de satın aldı
