Parçalar Mac MacBook 13" Core 2 Duo Late 2006 Wi-Fi Boards
Mağaza
Modelinizi bilmiyor musunuz? Mac cihazınıza ID atayın
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
$8,99
MacBook and MacBook Pro (Non-Retina) SSD Upgrade Bundle
Upgrade the storage and improve boot time and read/write speed in your MacBook and MacBook Pro (Non-Retina) with this SSD upgrade bundle.
$89,99'den
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
$7,99
Silicone 2.5" Hard Drive Enclosure with USB 2.0 Cable
Turn any SATA 2.5" laptop hard drive into an external storage drive with this part.
$9,99
500 GB 5400 RPM 2.5" Hard Drive / Toshiba
Replacement or upgrade hard drive compatible with all MacBooks, MacBook Pros, Intel Mac minis, and Sony PS3 and PS3 Slim game consoles. SATA interface for Intel Macs / 2....
$54,99
Universal Drive Adapter
Turn your current hard drive into an external drive with this part.
$24,99
MacBook Replacement Battery / White / New
Replace your dying or broken battery with this replacement. Compatible with all 13.3" MacBooks (excluding MacBook Unibody and MacBook Air). 4900-5200 mAh, 55 Watt Hours (...
$79,99
G4/MagSafe AC Adapter End
Replace a broken or damaged two-pronged tip of your square G4 or MagSafe adapter with this part.
$7,99
MacBook Display Inverter
Replace a broken or damaged display inverter for your MacBook with this part and fix backlight issues. This part is compatible with all 13.3" MacBooks (excluding MacBook ...
$14,99
MacBook (Core Duo/Core 2 Duo) Inverter Cable
Connects the logic board to the display inverter.
$19,99
Ürünler Gösteriliyor 1 - 10 of 62
Cihaz Bilgisi
Good became even better with the addition of Intel's Core 2 Duo processor!
The MacBook 13" Core 2 Duo (Late 2006) can be upgraded to a total of 3 GB of memory using a 2 GB RAM chip and a 1 GB RAM chip. The 500 GB 7200 RPM SATA hard drive will give you plenty of storage. The 8x SuperDrive is the fastest optical drive for this model and will make creating DVDs a whiz. You can also upgrade the upper case to the Penryn/Santa Rosa version with the new keyboard layout (including iTunes controls)!
There is one main variation within this model. Your machine may be a Energy Star-equipped or non-Energy star version. This affects the battery connector and logic board. See photos and part descriptions on the non-Energy Star or Energy Star battery connector/sleep sensors for information on determining which version you have.
Check out our MacBook troubleshooting page for help in diagnosing your machine!
Select your category below or browse all compatible parts to find what you need to fix your laptop!
