Parçalar Mac MacBook 13" Core Duo Wi-Fi Boards
Mağaza
Modelinizi bilmiyor musunuz? Mac cihazınıza ID atayın
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
$8,99
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
$7,99
MacBook and MacBook Pro (Non-Retina) SSD Upgrade Bundle
Upgrade the storage and improve boot time and read/write speed in your MacBook and MacBook Pro (Non-Retina) with this SSD upgrade bundle.
$89,99'den
Silicone 2.5" Hard Drive Enclosure with USB 2.0 Cable
Turn any SATA 2.5" laptop hard drive into an external storage drive with this part.
$9,99
Universal Drive Adapter
Turn your current hard drive into an external drive with this part.
$24,99
500 GB 5400 RPM 2.5" Hard Drive / Toshiba
Replacement or upgrade hard drive compatible with all MacBooks, MacBook Pros, Intel Mac minis, and Sony PS3 and PS3 Slim game consoles. SATA interface for Intel Macs / 2....
$54,99
MacBook Replacement Battery / White / New
Replace your dying or broken battery with this replacement. Compatible with all 13.3" MacBooks (excluding MacBook Unibody and MacBook Air). 4900-5200 mAh, 55 Watt Hours (...
$79,99
MacBook Display Inverter
Replace a broken or damaged display inverter for your MacBook with this part and fix backlight issues. This part is compatible with all 13.3" MacBooks (excluding MacBook ...
$14,99
PC2-5300 1 GB RAM Chip
RAM Upgrade / 1 GB / PC2-5300 / Low Profile / 200 pin, 667 MHz
$8,99
G4/MagSafe AC Adapter End
Replace a broken or damaged two-pronged tip of your square G4 or MagSafe adapter with this part.
$7,99
Ürünler Gösteriliyor 1 - 10 of 58
Cihaz Bilgisi
The MacBook 13" Core Duo can be easily upgraded to a total of 2 GB of memory using two 1 GB RAM chips, and a 500 GB 7200 RPM SATA hard drive will give you plenty of storage. You can upgrade to the Santa Rosa/Penryn Upper Case, featuring a new keyboard layout (including iTunes controls)! The 8x SuperDrive is the fastest optical drive for this model and will make creating DVDs a whiz. Have you ever been caught sleeping while waiting for your file to transfer over slow wireless network? We can wipe away that unnecessary snooze-fest with the Airport Extreme 802.11n Card upgrade.
There is one main variation within this model. The heat sink thermal sensors may have three-wall or four-wall connectors. This affects the heat sink and logic board. See photos and part descriptions on the three-wall or four-wall heat sinks for information on determining which version you have.
Check out our MacBook troubleshooting page for help in diagnosing your machine!
Select your category below or browse all compatible parts to find what you need to fix your laptop!
