MacBook 13" Mid 2009 Logic Boards
Grab a toolkit for your MacBook 13" Mid 2009 model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
MacBook 13" Mid 2009 ile çalışan parçalar:
MacBook (Early 2009) 2 GHz Logic Board
Replace a 2 GHz logic board (motherboard) compatible with the Early 2009 MacBook. Ports: Mini-DVI Port, 1000BaseT Ethernet, Firewire 400, 2 USB 2.0, Audio in, Audio out. ...
MacBook (Mid 2009) 2.13 GHz Logic Board
Replace a 2.13 GHz logic board (motherboard) compatible with the Mid 2009 MacBook. Fix processing issues like unexpected shutdowns, reboots or water damage. Ports: Mini-D...
Cihaz Bilgisi
Apple introduced the Mid 2009 MacBook with a small speed bump and a redesigned heat sink (with no integrated thermal sensors).
The MacBook 13" 2.13 GHz (Mid 2009) laptop can be upgraded to a hefty, yet agile 750 GB 7200 RPM SATA hard drive Upgrade Kit. A total of 8 GB of PC2-6400 or PC2-5300 RAM can be installed, using two 4 GB chips.
Check out our MacBook troubleshooting page for help in diagnosing your machine!
Select your category below or browse all compatible parts to find what you need to fix your laptop!
