Parçalar Mac MacBook 13" Unibody (Model A1342) USB Boards
Mağaza
Modelinizi bilmiyor musunuz? Mac cihazınıza ID atayın
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
$8,99
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
$7,99
MacBook and MacBook Pro (Non-Retina) SSD Upgrade Bundle
Upgrade the storage and improve boot time and read/write speed in your MacBook and MacBook Pro (Non-Retina) with this SSD upgrade bundle.
$89,99'den
PC3-8500 4 GB RAM Chip
Replace or upgrade the RAM in your desktop, laptop, or game console for faster performance. Low Profile / 204 pin / 1066 MHz
$29,99
MacBook Pro 13" Unibody and MacBook 13" Unibody Fan / New / Black
Replace a malfunctioning or noisy fan compatible with several models of 13" MacBook and MacBook Pro Unibody laptops.
$8,99'den
Unibody Laptop Dual Drive
Increase the storage space in your laptop by replacing the optical drive with a second hard drive or SSD.
$24,99'den
Apple MagSafe 1 AC Adapter / 85 W / AC Adapter End / New
Replace a broken or damaged Apple MagSage 1 AC adapter with this part.
$39,99'den
MacBook Unibody (A1342 Late 2009-Mid 2010) Replacement Battery / New / Fix Kit
Replacement battery, compatible with all A1342 13" MacBook models.
$79,99'den
Silicone 2.5" Hard Drive Enclosure with USB 2.0 Cable
Turn any SATA 2.5" laptop hard drive into an external storage drive with this part.
$9,99
PC3-8500 8 GB RAM Chip
RAM / 8 GB / PC3-8500 / Low Profile / 204 pin, 1066 MHz
$54,99
Ürünler Gösteriliyor 1 - 10 of 41
Cihaz Bilgisi
In October 2009, Apple revamped the low-end MacBook to fit the unibody lineup. Retaining its polycarbonate casing, the new MacBook Unibody features an internal battery, a rubberized lower case, and an LED display. Apple also removed Firewire from the MacBook line.
Select your version above or browse all compatible parts to find what you need to fix your laptop!
