Parçalar Mac MacBook 13" Unibody (Model A1278) USB Boards
Mağaza
Modelinizi bilmiyor musunuz? Mac cihazınıza ID atayın
MacBook and MacBook Pro Unibody Plastic Feet / Part Only
Replace the black plastic feet on the lower case of your Unibody MacBook or MacBook Pro.
$4,99'den
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
$8,99
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
$7,99
MacBook and MacBook Pro (Non-Retina) SSD Upgrade Bundle
Upgrade the storage and improve boot time and read/write speed in your MacBook and MacBook Pro (Non-Retina) with this SSD upgrade bundle.
$89,99'den
MacBook Pro 13" Unibody and MacBook 13" Unibody Fan / New / Black
Replace a malfunctioning or noisy fan compatible with several models of 13" MacBook and MacBook Pro Unibody laptops.
$8,99'den
PC3-8500 4 GB RAM Chip
Replace or upgrade the RAM in your desktop, laptop, or game console for faster performance. Low Profile / 204 pin / 1066 MHz
$29,99
Unibody Laptop Dual Drive
Increase the storage space in your laptop by replacing the optical drive with a second hard drive or SSD.
$24,99'den
Apple MagSafe 1 AC Adapter / 85 W / AC Adapter End / New
Replace a broken or damaged Apple MagSage 1 AC adapter with this part.
$39,99'den
Silicone 2.5" Hard Drive Enclosure with USB 2.0 Cable
Turn any SATA 2.5" laptop hard drive into an external storage drive with this part.
$9,99
Universal Drive Adapter
Turn your current hard drive into an external drive with this part.
$24,99
Ürünler Gösteriliyor 1 - 10 of 51
Cihaz Bilgisi
Apple's introduction of the MacBook Unibody 13" introduced a new case milled from a single brick of aluminum. Also new to this version is a switch to SATA optical drives and the controversial loss of a Firewire port.
The MacBook Unibody 13" can be upgraded to 8GB of RAM using two PC3-8500 4 GB RAM chips. The hard drive can also be upgraded to a hefty, yet agile 500 GB 7200 RPM SATA hard drive.
Not sure what's wrong with your laptop? Check out our Troubleshooting Guide!
Select your machine above or browse all compatible parts to find what you need to fix your laptop!
